Re: Can anyone point me to fluid flow schematics for 727?
[Re: moparx]
#2558891
10/04/18 02:05 PM
10/04/18 02:05 PM
BradH
i too, wonder about those billet accumulator pistons. another question on those. do you run them with springs, or get the one that has the rod on the tip, keeping it up ? I mentioned above in my 09/25/18 12:01 AM post that I'd read a lot of discussions (that's putting it nicely) about using springs, no springs, blocker rods, etc. People have different opinions and approaches. FWIW, I'm going to try a heavy outer spring w/o restricting the piston travel and see how that works for me. "Your results may vary!"
[Re: BradH]
#2558914
10/04/18 02:40 PM
10/04/18 02:40 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
No matter what you do with the accumulator springs you won't feel any difference in the seat of your pants. The only change that's noticeable is blocking the accumulator piston.
The billet piston without the built-in blocker rod does seem like the solution for a problem that doesn't exist.
[Re: John_Kunkel]
#2558993
10/04/18 06:18 PM
10/04/18 06:18 PM
Posts: 1,544 CT
mrrandyj
CT
I don't think that all the people who have broken a stock plastic accumulator piston would agree with that statement.
[Re: mrrandyj]
#2559005
10/04/18 06:54 PM
10/04/18 06:54 PM
John_Kunkel
You don't need a pricey billet piston to replace the plastic one, a factory cast aluminum one will do.
[Re: John_Kunkel]
#2559081
10/04/18 09:26 PM
10/04/18 09:26 PM
Posts: 1,544 CT
mrrandyj
CT
You don't need a pricey billet piston to replace the plastic one, a factory cast aluminum one will do. Believe it or not, good used factory cast aluminum accumulators are not as easy to find as they use to be, especially if you need to have a regular supply of them. Chrysler hasn't put them in anything since the 80's (over 30 years). No Cummins powered truck came with the cast aluminum accumulator, no overdrive transmission ever came with the cast aluminum accumulator. The switch to plastic happened before either of those even existed. There is a huge market for people that are building transmissions for Cummins trucks and people building performance overdrive gas transmissions. Most shops that specialize in rebuilding those transmissions wouldn't even reuse the plastic accumulator in a completely stock rebuild. If someone building a transmission thinks that 45 bucks is too "pricey" for a part that is readily available and completely solves a problem that does exist, well, I guess I don't really have an answer for that.
