Re: Dyno guess 440 stroker - my A12 upgrade
[Re: sogtx]
#2555850
09/28/18 07:46 AM
09/28/18 07:46 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Wow In the heat of dynoing i really wish we would have done the air cleaner baseplate last week . So i did some googling - I guess im not the only one with different results of torque .. HR six Pack Dyno
[Re: sogtx]
#2555909
09/28/18 11:35 AM
09/28/18 11:35 AM
When I tested the 6bbl FAST motors, we always ran with the air filter in place, since that’s how they are run in the car.
On a mild 446 build similar to the one in the link, I tested the filter base with no element or lid, against the complete filter. The complete filter was down pretty much everywhere.
The bsfc numbers were actually slightly better with the complete filter on, but the power was lower. With the element and lid installed the motor was using about 10-15lbs/hr less fuel at the upper end of the pull.
These are back to back tests done 4 minutes apart....... never even shut the motor off.
[Re: sogtx]
#2556080
09/28/18 08:19 PM
09/28/18 08:19 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Aftermarket World/Mopar block. What's the bore? .070 over? 4.570? Just trying to guess the actual cubic inch It's cool if you'd rather not say.....hell of a runner!
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2556183
09/29/18 07:44 AM
09/29/18 07:44 AM
sogtx
upstate western ny
Aftermarket World/Mopar block. What's the bore? .070 over? 4.570? Just trying to guess the actual cubic inch It's cool if you'd rather not say.....hell of a runner! 4250 stroke / 7.1 rods Old 90’s 505 crate motor MP performance block Bores bushed and sleeves installed from MP from new - didnt know til we started the build, lol. So it allowed for 70 over easily . I think its 515 ish . Dished diamond pistons / 9.5 ish compression. The TF 240’s were an afterthought after reviewing costs. In pretty sure they cc’d less than my actual 84 cc’d on my 452 castings - The book shows 78cc on the 240’s. getting the Cast heads re-ported and flowed to breathe better than before would have cost more thsn new AL heads that came CNC ported but I dont believe polished since i can just barely see my reflection in them, lol. This was supposed to be a 9:1 motor cast heads to run on watered down gas. I kind of only originally wanted 550 reliable horse with consistent torque. lol. I would say I should be able to intimidate hellcats - my post car is only 3800 lbs or less .. So I guess Ill take it .
[Re: sogtx]
#2556185
09/29/18 08:06 AM
09/29/18 08:06 AM
Posts: 9,872 Weddington, N.C.
Streetwize
Weddington, N.C.
That's very impressive power for such a street friendly compression pump gas motor.
Couple quick questions:
Was any porting done to the intake manifold? It'd be interesting to see the Six Pack compared to a conventional ported (able to keep up with the heads) Single plane ~950 Holley DP in terms of torque/HP with the trick flows
I'm presuming the cam was targeted for use with Exhaust manifolds and a stock sounding idle? Guessing from the wide 113.5 lobe spread and relatively late intake centerline. Do you have the torque graph from the dyno. What I'm interested in is the torque peak rpm and over how wide an RPM range the motor maintained 95% of peak torque,
Thanks and Congrats!!
[Re: sogtx]
#2556192
09/29/18 08:55 AM
09/29/18 08:55 AM
Posts: 2,466 Answering the call of the wild
ThermoQuad
I understand that posting in the race section is not allowed by corner carvers like me as we have no clue how to go fast. That an honest statement based on years of observation on here so don't get your shorts in a wad -a friendly poke is needed here. After our nite visiting the dyno i gave sogtx a check list of what was wrong with the six pak and where the missing 35 hp is. We will see if they can get the number they want properly. I identified some fundamental issues with the baseline set up of the six pak that are obviously affecting the pulls. Six paks are a unique beast. Carbs are over jetted and using old info -staggered jets- without any data to prove the need. The motor never gets a chance to come off from being fat. Secondaries come in way too soon. I am told it ran great with the headers but if you don't understand how it is supposed to run that info don't mean squat. I noticed raw fuel in the intake when we were changing jets. Engine temp should be 195-200 not 190 The biggest mistake was not baselining the carbs per the guide and 2nd was not running the engine on center carb against the dyno without the secondaries to observe the fuel curve and determine where the power was falling off - now make the secondaries come in before that pt. People do not follow the proper advice, the engine gurus should have read the guide -start with black springs in the secondaries. I also noticed the the fuel was not just plain 91 octane no ethanol. The afr's required are different betwix gasolines. Look it up. I don't understand the thinking here, who gives a crap how much hp it makes on witches brew. I am waiting for the results to see what the results of my suggestions are.
[Re: ZIPPY]
#2556196
09/29/18 09:11 AM
09/29/18 09:11 AM
sogtx
upstate western ny
Aftermarket World/Mopar block. What's the bore? .070 over? 4.570? Just trying to guess the actual cubic inch It's cool if you'd rather not say.....hell of a runner! Block details
[Re: ThermoQuad]
#2556197
09/29/18 09:17 AM
09/29/18 09:17 AM
sogtx
upstate western ny
Lol . Dilbert Patience is a virtue that must be had We can test on dyno til the cows come home Somehow , i know itll be a tad different when in car and all that air is getting pushed through the huge hood scoop and cats ars suffocating . Based on numbers something was efficient .. Id be still happy if we didnt find 35 hp. But i will prove the 4 barrel people wrong after we switch Back to headers . Btw Quad - theres an LS motor ad under your recent post And dont have a good image of curvd , but heres some data
[Re: sogtx]
#2556199
09/29/18 09:30 AM
09/29/18 09:30 AM
Streetwize
Weddington, N.C.
Re: intake porting
Nothing against Wilson because their results are Epic, but as a potentially lower cost option you may want to consider sending the intake to Larry Smith over at HPEngines.net
Larry has 35+ years of NASCAR experience and built the Dodge motors that went 1-2 at Daytona for Penske. He ported the 337 intake for my 517" low deck. If there's flow and power to be found, Larry's your Huckleberry.
[Re: sogtx]
#2556205
09/29/18 10:00 AM
09/29/18 10:00 AM
ZIPPY
S.E. Michigan
Aftermarket World/Mopar block. What's the bore? .070 over? 4.570? Just trying to guess the actual cubic inch It's cool if you'd rather not say.....hell of a runner! Block details Awesome. The hemi motor mount pad in the other pic kind of jumped out at me lol
Rich H.
Esse Quam Videri
[Re: sogtx]
#2556251
09/29/18 01:08 PM
09/29/18 01:08 PM
Posts: 1,699 central il.
second 70
central il.
Aftermarket World/Mopar block. What's the bore? .070 over? 4.570? Just trying to guess the actual cubic inch It's cool if you'd rather not say.....hell of a runner! Block details That's a 4.50 siamese bore mega block. Just because the casting is the 2468330 M hemi # doesn't make it one. I beleive the mega block wedges as well used that number. The mopar cast above the number tells you it's a 4.5 the standard non siamese water block doesn't have the mopar casting on it but is a 2468330 M block also. Mike
[Re: sogtx]
#2556270
09/29/18 01:53 PM
09/29/18 01:53 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I’ve tested a few different set ups on my roadrunner. 511ci pump gas motor with Indy SR’s. My six pack ran pretty much identical to a 1050/4150 AN carb on a ported TM6. Both went 10.90’s at 4000# through mufflers. I did tune a dominator (for another car) on the rr. That felt real strong but I don’t have any numbers to back it up. Butt dyno says it had the six pack covered though. Same deal as you, I wanted to prove the six pack could at least run with a well prepped 4150 carb which it did.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#2556291
09/29/18 03:09 PM
09/29/18 03:09 PM
Posts: 43,127 Bend,OR USA
I did several different dyno testing sessions om my old pump gas motor on two different dynos, a DTS and the local Studka when it wasn't calibrated correctly. My message is on MY test on the Studka show 7 HP more with the six pack set up like I ran it on the street and race it with the 3.0 exhaust system corked up, I used a Team G intake with a known good Holley 1050 CFM List # 9375 non HP carb, the torque was exactly the same on most of the same RPMs I didn't do any testing with the same heads and the different intakes and carbs at the track
[Re: Cab_Burge]
#2556310
09/29/18 04:14 PM
09/29/18 04:14 PM
sogtx
upstate western ny
I could do this dyno stuff ALL weekend every weekend Every change is like Christmas morning , lol. I had to leave - guys are jettin up 1 more size 700 ft lbs and 669 hp is enough to kill me .. And we had the top corked with the Air cleaner
[Re: sogtx]
#2556448
09/29/18 11:24 PM
09/29/18 11:24 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I could do this dyno stuff ALL weekend every weekend Every change is like Christmas morning , lol. I had to leave - guys are jettin up 1 more size 700 ft lbs and 669 hp is enough to kill me .. And we had the top corked with the Air cleaner Is this with Headers ?
[Re: CSK]
#2556535
09/30/18 08:00 AM
09/30/18 08:00 AM
sogtx
upstate western ny
I could do this dyno stuff ALL weekend every weekend Every change is like Christmas morning , lol. I had to leave - guys are jettin up 1 more size 700 ft lbs and 669 hp is enough to kill me .. And we had the top corked with the Air cleaner Is this with Headers ? Yes ..
