Re: 2012 Cummins engine check light and warning
[Re: fastmark]
#2547820
09/09/18 08:48 AM
09/09/18 08:48 AM
Guitar Jones
You will have to take it out on the highway for a drive. I don't remember exactly but I think it's over 45 MPH for 20 minutes. Your owners manual should have the specifics.
[Re: fastmark]
#2548263
09/10/18 09:03 AM
09/10/18 09:03 AM
Guitar Jones
It doesn't use DEF but still needs to clean the particulate filter. The DEF is only for NOX emissions as far as I know, it doesn't help to clean the filter. Like I said, it should all be in the owners manual.
[Re: fastmark]
#2548347
09/10/18 01:04 PM
09/10/18 01:04 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Mine does not have the system that uses the def fluid but I guess it’s still the same deal, correct? Correct - mine does not use the fluid either. Do not let it get clogged all the way or it will stop running and then it's a dealer regen that cost $$$$.
[Re: J_BODY]
#2553171
09/22/18 08:16 AM
09/22/18 08:16 AM
Posts: 6,389 Abilene, Texas
fastmark
Abilene, Texas
Working on these trucks I’d delete that era of pickup so fast it’d make your head spin. The 13 newer with DEF has been a much more reliable package. Not really an option for me. It’s paid for only has 20,000 miles. I’m considering deleting stuff since it’s out of warranty.
[Re: fastmark]
#2553193
09/22/18 11:11 AM
09/22/18 11:11 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
We have four of that era truck at work.... 1 tech, 2 sales guys, and our service manager. ALL deleted... we still stock two turbos for the 07-12 6.7's. It seems when things go sour with that system, they go big and they go expensive!! Key to delete is doing it before you have a problem. I think you'll find it's money well spent, especially if you are keeping the truck. You'll be able to extend your oil changes (saves you money) since you won't have regen events polluting your crankcase oil with fuel. You should also see a substantial MPG increase up there with the newer DEF equipped trucks.
I nearly bought an 11 last year with full intent of deleting it, but the price was high and after pulling my race trailer with it, I either have a pretty good tune in my 01, or that 11 was a dog!!
btw EFI Live Wire seems to have a pretty good package and support. H&S used to, but after getting their nuts squeezed by the EPA, they only sell now and if you have a prob good luck getting it resolved.
[Re: fastmark]
#2554372
09/25/18 09:44 AM
09/25/18 09:44 AM
fastmark
Abilene, Texas
Working on these trucks I’d delete that era of pickup so fast it’d make your head spin. The 13 newer with DEF has been a much more reliable package. Not really an option for me. It’s paid for only has 20,000 miles. I’m considering deleting stuff since it’s out of warranty. Thanks for the clarification. I thought you meant sell the truck.
