Re: Transmission removal without a lift [Re: GoodysGotaCuda] #2538161
08/18/18 03:47 PM
08/18/18 03:47 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
did it many times, tall jack stands,floor jack...2x4 between drag link and oil pan
Re: Transmission removal without a lift [Re: Joesixpack] #2538168
08/18/18 04:01 PM
08/18/18 04:01 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i always slide mine off onto a low profile creeper.
Re: Transmission removal without a lift [Re: bonefish] #2538174
08/18/18 04:29 PM
08/18/18 04:29 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
In the past I have used a floor jack to set it down on stacks of 2x and 4x wood under the front and rear of the transmission. Then I slid the jack out and removed the wood at each end one piece at a time until it was on the ground and pulled it out. Installation was the same procedure in reverse.
As long as you have enough ground clearance between the top of the bell housing when it's on the ground and the rocker panel your good.
Re: Transmission removal without a lift [Re: gzig5] #2538189
08/18/18 05:45 PM
08/18/18 05:45 PM
Mequon, WI
gzig5 Offline OP
gzig5  Offline OP
Mequon, WI
I've got it up right now to work on the front suspension and I've got at least 17" to the floor pan and I can get a couple more inches if I need to. Now the question will be, do I want to mess with it when the time comes...
Re: Transmission removal without a lift [Re: gzig5] #2538335
08/19/18 12:27 AM
08/19/18 12:27 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I have used allthread fo make long studs to make it easy lining up the trans for reassembly too.
Re: Transmission removal without a lift [Re: gzig5] #2538396
08/19/18 01:42 AM
08/19/18 01:42 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I used to be able to do it on the floor,but when the age catches up the mind says yes,,,and the body says NO.That being said I used the floor jack till I bought the M/C jack.Either way I had to tilt the tail up to clear the bellhousing to get it out fromunder and twist the trans to clear the headers.Just need to be carfull with the trans getting on & off the jack you're using.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Transmission removal without a lift [Re: gzig5] #2538444
08/19/18 07:32 AM
08/19/18 07:32 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Looks like the same craftsman motorcycle jack I use....I paid $89 for it
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
