Proper interference fit for rod -piston pin bushing- install
#2534413
08/10/18 11:51 PM
08/10/18 11:51 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
What is the reccomended interference fit for a rod -piston pin bushing- install?
0.0015" or would 0.002" be better????
I dont wanto to just drive em at room temp because I dont want to risk shaving them off as they get driven in, and loosing some of that interference fit that will make em stay in place.
I was planning on installing them by dipping the rod in boiling water and putting the bronze bushings on dry ice.
Then driving them in with a stepped driving tool turned to the exact dimensions for the bushings im gonna be driving in.
I am thinking this would be the better way to do it to achieve a better and more snug fit -when they get back to room temp- without any damage to the OD of the bushings, and then hone them to size....given I dont have access to a machine shop that has roller burnishing tools locally.
Re: Proper interference fit for rod -piston pin bushing- install
[Re: domingo]
#2534436
08/11/18 01:23 AM
08/11/18 01:23 AM
Posts: 4,457 Washington
madscientist
Washington
If you are talking press fit into the rod you only need .0008-.00010 and no more.
[Re: domingo]
#2534468
08/11/18 03:18 AM
08/11/18 03:18 AM
madscientist
Washington
Im talking about installing a bronze bushing on the small end of the rod.
Question for the machinists in the forum.
How much interference fit to use if indirect heating the rod in boiling water and puting the bushing in dry ice before driving it in. If you have .001-.0015 press that's plenty. I have never ever heated and rod and frozen the bushing to install them. There is no reason to either of those things. I put a little oil or even anti seize in the bore and push them in. We had a little press for doing crap like that and it broke one day. So I carefully used a vise with soft jaws and pressed them in.
[Re: domingo]
#2534512
08/11/18 11:29 AM
08/11/18 11:29 AM
Posts: 4,206 New York
polyspheric
I read about using a full floating bushing 100 years ago, and it made my head hurt.
Boffin Emeritus
[Re: domingo]
#2534685
08/11/18 05:55 PM
08/11/18 05:55 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
I think .0015-.0020" press fit would be OK and the heat/cool installation method will work OK but, in an ideal world, the best way to final size the ID of the bushing is not to hone it but to burnish the inside by pressing a correct size steel ball through its bore. This not only sizes it but expands it against the rod bore much like installing an intermediate shaft bushing.
[Re: John_Kunkel]
#2534802
08/11/18 10:31 PM
08/11/18 10:31 PM
domingo
EL Master
EL Master
Lima, Peru
I think .0015-.0020" press fit would be OK and the heat/cool installation method will work OK but, in an ideal world, the best way to final size the ID of the bushing is not to hone it but to burnish the inside by pressing a correct size steel ball through its bore. This not only sizes it but expands it against the rod bore much like installing an intermediate shaft bushing. Living in Peru and playing with old musclecar engines, far from an ideal world! So I guess I will go with 0.002" interference and the heat/cold method. The machine shops down here dont have burnishing tools, I asked at several and they dont even know that tool exists. Reconditioning some old rods from a rotating assembly thats already balanced to those rods. I have other engines with H beam rods and brand new internals, just not this one. Just trying to make things work and not end with a time bomb.
