Re: Horn not working when running.
[Re: fullmetaljacket]
#2510080
06/18/18 06:08 PM
06/18/18 06:08 PM
We're always nice! ground the terminal at the horn relay that goes to the coulumn & see if it sounds. clean/check your terminals for tightness. make sure the coulumn is grounded (it might have a short pigtail for this with a ring terminal at each end). Jump fire to the horn power in terminals.
#2511329
06/21/18 02:24 PM
06/21/18 02:24 PM
Posts: 5,777 ohio
ruderunner
ohio
New problem or been like that?
Could be a wiring problem, either lack of power key on or a ground going away key on.
Will it do the same thing if the key is in run but the engine is not running?
Angry white pureblood male
