Re: Cam break in, windage tray?
[Re: 500ciBee]
#2499491
05/23/18 02:04 PM
05/23/18 02:04 PM
Posts: 14,493 So. Burlington, Vt.
If you're confident that the heads are currently set up with springs that are installed to provide 105lbs on the seat and 295lbs at peak valve lift with the cam/rockers you're running...... It should be fine.
Use actual break in oil.
