Circuit Board Question (Non Rallye B Body) #2497238
05/17/18 04:01 PM
05/17/18 04:01 PM
Dearborn, Michigan
gtxncuda Offline OP
gtxncuda  Offline OP
Dearborn, Michigan
I'm in process of upgrading the bulbs on my Road Runner's cluster to LED's (so I can actually see them at night!) As many of you know, the polarity is key with the LED's as in they only work one way, unlike the pop in incandesant bulbs. I don't have an FSM, (yeah, I plan to by a CD) but am trying to determine with one on the printed circuit is positive, and which is negative? Does anyone have insight into this or an illustration that would help? Just an an FYI for someone cinsidering this, the Chinese LED's and "correct 5/8" sockets sold on eBay "for most 60's and 70 Mopars" do NOT fit! The LED's are fine, but the sockets are too small. Semi-related, what bulb/socket does the in dash tach use? Is there a stand alone harness for the bulb? I installed a repro tach, but not sure how to illuminate it?
As always, thank Moparts!
1971 Cuda 340 auto
2013 Mustang Boss 302 L/S
1969 Road Runner RM21 440 4 speed
Re: Circuit Board Question (Non Rallye B Body) [Re: gtxncuda] #2497286
05/17/18 06:01 PM
05/17/18 06:01 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Just trace the circuit on the board. They are very simple.
Re: Circuit Board Question (Non Rallye B Body) [Re: gtxncuda] #2497436
05/18/18 02:32 AM
05/18/18 02:32 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
One side of the bulb will go to a pin on the circuit board (12v), the other to the case (ground).
Re: Circuit Board Question (Non Rallye B Body) [Re: Jim_Lusk] #2497508
05/18/18 12:22 PM
05/18/18 12:22 PM
Dearborn, Michigan
gtxncuda Offline OP
gtxncuda  Offline OP
Dearborn, Michigan
Thanks Jim!
1971 Cuda 340 auto
