Small block front machining #2488010
04/25/18 11:23 PM
04/25/18 11:23 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
I have a 340 block that needs to get remachined on the front face. The timing cover always has trouble sealing coolant. Was wondering it anyone has ever cut this surface.
Attached PDF document
3409.pdf (30 downloads)
Re: Small block front machining [Re: NoFrills] #2488013
04/25/18 11:27 PM
04/25/18 11:27 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
Sorry wrong pic
Re: Small block front machining [Re: NoFrills] #2488017
04/25/18 11:43 PM
04/25/18 11:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You could machine it. Also could blast it clean,then JB weld. Block it flat with a stone. Actually if it was good and clean good RTV would seal it.
Doug
Re: Small block front machining [Re: dvw] #2488035
04/26/18 12:13 AM
04/26/18 12:13 AM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I was told it was epoxyed once before. The last time it was hot tanked it took it all off. Was also thinking about possibly spot facing around the hole with a annual cutter in a magnetic drill and putting a o ring in the hole.
Re: Small block front machining [Re: NoFrills] #2488046
04/26/18 12:50 AM
04/26/18 12:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Take a belt sander to it.. just be slow and careful
then seal it off with RTV
wave
Re: Small block front machining [Re: MR_P_BODY] #2488072
04/26/18 01:47 AM
04/26/18 01:47 AM
RapidRobert Offline
RapidRobert  Offline
I'd clean it surgically clean (wirebrush if needed) then the gasket AND TRS gasket cement. It has sealed stat necks that would not seal (drawfiled flat/gaskets/RTV).
Re: Small block front machining [Re: NoFrills] #2488080
04/26/18 02:07 AM
04/26/18 02:07 AM
P
Porter67 Offline
Porter67  Offline
P
The grey rtv gm uses would also work, so well youd need a rubber mallet to get the cover off next time.
