Re: 727 rebuild questions, diaphram spring and wave springs
[Re: crash520]
#2486300
04/22/18 03:40 AM
04/22/18 03:40 AM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Video claims the later piston isn't thicker but it is; the early 2124834 piston does measure .780" thick but the '74-later 3743623 piston measures .830". The thicker piston is needed because of the reduced cone height of the new Belleville. The later piston and Belleville were introduced to prevent the exact same failure mentioned in the video.
Use of the late piston and Bellevile along with replacing the wavy snap ring with the thickest solid snap ring (.106") makes the rear clutch a lot more reliable without the big bucks for the billet parts.
[Re: crash520]
#2486464
04/22/18 05:24 PM
04/22/18 05:24 PM
John_Kunkel
.012"-.015" per disc is the desired clearance so .060"-.075" is good for five discs with a flat snap ring.
[Re: FurryStump]
#2488385
04/26/18 06:05 PM
04/26/18 06:05 PM
John_Kunkel
You're correct, we've had this discussion before; there are examples of "new" pistons with the new P/N that are the old dimension but my measurement was taken from an original 623 piston.
In the factory list of running changes for the '74 model year they list a new "N-D (Neutral-Drive) package" that includes the new Belleville and a new piston with "an increase in the over-all height".
