Re: Summit Codes
[Re: fuseable]
#2483582
04/16/18 01:40 PM
04/16/18 01:40 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Guys I'm not gonna be able to use the code that I saved for myself. Expires tonight.
Looks like EWJ is next in line, then Scotts71Chall, then Fishtix. Is that correct? If you can't use it by tonight I'll move on to the next guy.
Re: Summit Codes
[Re: fuseable]
#2483824
04/16/18 08:36 PM
04/16/18 08:36 PM
ProSport
Akron, Ohio
I haven't heard back from thewolf1970, Whitedart is covered as he got a code from someone else. Can anybody use this last code tonight?
Re: Summit Codes
[Re: fuseable]
#2483835
04/16/18 08:48 PM
04/16/18 08:48 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
ProSport, I just sent you one that I got from Jeff.
Re: Summit Codes
[Re: fuseable]
#2483839
04/16/18 08:57 PM
04/16/18 08:57 PM
Hemi_Joel
Minnesota
I have one extra that expires 4-22
Re: Summit Codes
[Re: Hemi_Joel]
#2483850
04/16/18 09:18 PM
04/16/18 09:18 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
I have one extra that expires 4-22 I could use that one for some tires and wheels ive been looking at
Re: Summit Codes
[Re: fuseable]
#2483872
04/16/18 09:48 PM
04/16/18 09:48 PM
ProSport
Akron, Ohio
dd340 and Ogopogo, can one of you use a code tonight? Or do you need the code for 4/24?
Re: Summit Codes
[Re: fuseable]
#2483886
04/16/18 10:02 PM
04/16/18 10:02 PM
ProSport
Akron, Ohio
I'm leaving for the evening so here's the code if anyone can use it tonight. I realize it should be done through private message but I'm out of time.
