Race driveshaft measurement questions
#2469328
03/20/18 07:39 PM
03/20/18 07:39 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Hey guys need some help. I am swapping my 727 out for a 904 here shortly. Have a 69 Dart. Has ladder bar suspension, so not sure the rearend( 8:75/ 489 case) sits exactly where it would have from the factory. Anyhow, i am hoping to do the swap all in one day for several reasons.
So my thought is to find out if i can what the measurements are supposed to be were one to order a driveshaft for my car the way it came from the factory(340/727) if somebody hopefully has them, then measure what i actually have. If they agree, the rearend is where its supposed to be. Then knowing that, i can hopefully find measurements for a 904, and order up a driveshaft and have it on hand the day i do the swap Make sense? If the factory 727 measurements are correct, should be fairly easy to determine what i need measurements wise for the 904. Somebody has probably already done this on here...... i hope
TIA
Re: Race driveshaft measurement questions
[Re: AndyF]
#2469433
03/20/18 11:10 PM
03/20/18 11:10 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Cass at Doctor Diff can help you out. He has a form on his website for the Strange driveshafts. I used the Strange order form and it came out perfect with nice solid 1350 joints and a new slip yoke. Gus
[Re: B3422W5]
#2469646
03/21/18 12:20 PM
03/21/18 12:20 PM
B3422W5
Portage,michigan
Think people missunderstood what i need. I know the different driveshaft makers have measurement charts. What i need are those measurements someone has taken for a car with 727 and 8.75 using a 69 Dart or equalivent. I can then compare that to my actual measurements, to make sure my rear is in stock location. Knowing that, i can then hopefully get 904 measurements as well, without having to actually put the 904 in the car and have it sit while i order a driveshaft. I want to order my 904 shaft ahead of time for the swap in other words, and if everything is in stock locations, others must have taken these measurements already that i can use to order from
[Re: B3422W5]
#2469750
03/21/18 03:24 PM
03/21/18 03:24 PM
B3422W5
Portage,michigan
Got what i was looking for from posting same thing on another site 69 Dart with v8 and 727........ 47.81 inches center of yoke to center of yoke 69 Dart with v8 and 904.........52.27 inches center of yoke to center of yoke
So now if the 727 in my car is the same 47.81 inch measurement, i can add the extra length of the 904 measurement on an order a 904 driveshaft with very good chance it will fit as it should. That way i can have everything on hand to do the swap without waiting to order stuff.
[Re: B3422W5]
#2469827
03/21/18 05:38 PM
03/21/18 05:38 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Don who are you going to have do your new shaft? When I mini tubbed my dart I had Dynotech build me a nice shaft with 1350 u joints. The car has always had a vibration since. I thought maybe my pinion angle or drive line angles were off and over the course of several years tried different angles but nothing helped.
I've been working on the car for a couple months changing a few things and had the transmission out, while it was out I decided to have my local drive shaft builder check my Dynotech shaft for balance. It was way out, he said he thought it was going to jump out of the machine. He added a big weight on each end to balance it, when I went to pick up he ran it in his balancer and showed me the indicators and there was very little movement on either end.
It may just be a fluke but IIRC that shaft was well over $400 and has caused me much grief and wasted time chasing my tail.
BTW, I haven't ran it yet and and will not until I get this brake pressure figured out.
[Re: justinp61]
#2469942
03/21/18 08:02 PM
03/21/18 08:02 PM
B3422W5
Portage,michigan
Gonna have a local outfit do a steel one. They built one for member scottb( my local buddy) and he went 9.40’s with 1.2xx 60 foots in his 68 r5p7 Dart with zero issues. Should be fine for my pooch
[Re: Racer33]
#2469944
03/21/18 08:03 PM
03/21/18 08:03 PM
B3422W5
Portage,michigan
If you chart is correct assuming the same rear end in both the 904 and 727 cars you should be able to just order a driveshaft that is 4.46" longer then your existing driveshaft even if your axle is not in the stock location Yep. Exactly my plan..... just do a couple of measurements to verify
