Re: 727 for SS hemi
[Re: sixpacksteve]
#2467920
03/17/18 11:53 PM
03/17/18 11:53 PM
Posts: 3,395 Pa
Hot 340
Pa
Doug, i glad you had great luck. i've been thru aleast a dozen 727 trans, i have 200 less HP and a coan trans now. has been rebuilt several times. I personally believe if you go more than 600+hp 727 Not the way. Im happy for the guys that have been. Someone needs a new tranny guy.
Re: 727 for SS hemi
[Re: Hot 340]
#2467922
03/17/18 11:56 PM
03/17/18 11:56 PM
Posts: 764 NW Pa.
KD800X
NW Pa.
Doug, i glad you had great luck. i've been thru aleast a dozen 727 trans, i have 200 less HP and a coan trans now. has been rebuilt several times. I personally believe if you go more than 600+hp 727 Not the way. Im happy for the guys that have been. Someone needs a new tranny guy. I agree! I know guys going 8.60's in full body cars with a 727's.
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2468019
03/18/18 10:29 AM
03/18/18 10:29 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Almost 950ft/lb here. Only time it's broke has been when we took some teeth off the ring gear (Dana 60). Broke the O/P shaft and rolled the sprag. It's got a lot of aftermarket stuff inside, nothing lightened just all the H/D steel stuff you can get and has worked great, although now I've probably jinxed it
Re: 727 for SS hemi
[Re: Hot 340]
#2468113
03/18/18 02:38 PM
03/18/18 02:38 PM
Posts: 43,127 Bend,OR USA
Doug, i glad you had great luck. i've been thru aleast a dozen 727 trans, i have 200 less HP and a coan trans now. has been rebuilt several times. I personally believe if you go more than 600+hp 727 Not the way. Im happy for the guys that have been. Someone needs a new tranny guy. Who knows what used parts have been through before the average tranny builder reuses them I like new good race parts from Dave Smith in all of my all out race trannys that he builds for me
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2468520
03/19/18 11:47 AM
03/19/18 11:47 AM
an8sec70cuda
I'm at about 1100 hp w/ a 727 in a 3900 lb car. 8.90s at 150 mph. Billet steel drum, TA transbrake (no LBA), A&A 5 pinion planetary, bolt in sprag, cast deep pan, your normal good clutches, etc. and that's it. The rest is stock stuff. Knock on wood, it's been good so far.
Re: 727 for SS hemi
[Re: A727Tflite]
#2468569
03/19/18 01:42 PM
03/19/18 01:42 PM
Posts: 9,826 MI, usa
dvw
MI, usa
That's half the battle building a good trans - knowing what's good and what's not. Guys can buy the "build a trans" book but that only gets it assembled. Using parts on the verge of failure only gets you limited life - guys that know what to look for don't use those parts. Starting with a good core takes a lot of risk out of the build.
Exactly. There is a difference between a builder and aN assembler. This stuff is old. Some wear in the sealing areas, where rotating parts ride, etc. Most of the time the stuff us pretty good, but not always. Mine needed a reaction shaft support this freshen. Not broke, just worn in the sealing ring land. Doug
Re: 727 for SS hemi
[Re: dvw]
#2468950
03/20/18 07:52 AM
03/20/18 07:52 AM
Posts: 4,066 Mo.
racerx
Mo.
Exactly. There is a difference between a builder and aN assembler. This stuff is old. Some wear in the sealing areas, where rotating parts ride, etc. Most of the time the stuff us pretty good, but not always. Mine needed a reaction shaft support this freshen. Not broke, just worn in the sealing ring land. Doug ..100% I have a few freshen under my belt (1 727,1 46h)both with good cores. I'm no expert for sure. I guess I out.
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2469445
03/20/18 11:31 PM
03/20/18 11:31 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Pro Trans vote here. My is behind a 605” Hemi in a all steel 65 Coronet. Very happy with it.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: 727 for SS hemi
[Re: cudaman1969]
#2469460
03/20/18 11:54 PM
03/20/18 11:54 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
Back in the 60s early 70s most all funny cars used TFs, how much HP did a blown nitro Hemi make then? They called them torchflites back then too lol. I'd say about 2000hp back then
