Bent strut - how much is too much? #2467315
03/16/18 01:34 PM
03/16/18 01:34 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
In the process of rebuilding my '71 Satellite front suspension, and discovered one of my struts is slightly bent. Looks like it's between 1/8" and 5/32" off center:
https://photos.app.goo.gl/JvDiDc6YoizXBDdy1
Opinions? Can I use as is? Should I find a good used one? Or just have it straightened? Thanks for weighing in.
Roger
Re: Bent strut - how much is too much? [Re: Fab64] #2467328
03/16/18 02:06 PM
03/16/18 02:06 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i wouldn't worry too much about that bend, but look real closely at the control arm and the area in the k-member where the strut rod bolts up. make sure nothing is bent or deformed.
Re: Bent strut - how much is too much? [Re: Fab64] #2467330
03/16/18 02:07 PM
03/16/18 02:07 PM
rarefish Offline
rarefish  Offline
I think it is usable as is or you can try to straighten it a little. Bent strut rods and not uncommon. One thing you can say is a bent strut rod is a shorter strut rod which increases the positive caster.
Re: Bent strut - how much is too much? [Re: rarefish] #2467352
03/16/18 03:08 PM
03/16/18 03:08 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Have yet to see an oem one that wasn't bent at least a little.
Can you even buy new stock ones?
Re: Bent strut - how much is too much? [Re: Neil] #2467464
03/16/18 07:35 PM
03/16/18 07:35 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks, guys.
My LCA looks okay, as does the K-member. I've not seen any new, OE type, struts for sale. I may just go ahead and run this one as is. Thanks for the help.
Roger
Re: Bent strut - how much is too much? [Re: Fab64] #2467538
03/16/18 10:43 PM
03/16/18 10:43 PM
IN
ahy Offline
ahy  Offline
IN
They often had a bend or at least "dog leg" as new. Looks OK for use to me.
