Re: stroker kit
[Re: moparmatt0]
#2467007
03/15/18 06:16 PM
03/15/18 06:16 PM
an8sec70cuda
A KB block w/ B1 heads is gonna be a pretty serious piece. I'd put some quality, higher end, parts in that build. A good engine shop could put together a "kit" for you, but I doubt you'll find any online mail order kit like that.
Re: stroker kit
[Re: moparmatt0]
#2467087
03/15/18 09:34 PM
03/15/18 09:34 PM
sgcuda
You won't find a kit. B1 heads have a different valve angle than say Indy's or Trick Flow, so there are no shelf pistons available. Plus, the amount of power that the B1 heads can produce are more than what most "Economic" rotating assemblies can handle. You are going to want some good parts in that combo.
[image][/image]
Re: stroker kit
[Re: moparmatt0]
#2467138
03/15/18 11:31 PM
03/15/18 11:31 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a kieth black block with b-1 original heads currently is a 499 looking for more displacement who has the best deal will be used for drag race only thanks for any help Matt. I would call Koffels they might have the parts on the shelf for that combo Gus
Re: stroker kit
[Re: moparmatt0]
#2467164
03/16/18 12:28 AM
03/16/18 12:28 AM
Posts: 43,127 Bend,OR USA
What size is the current bore? On your deal I would look at buying and using a 4.25 billet steel center counter weighted crankshaft(check with Ohio Crankshaft for a good deal on them ) with either BB Chevy 2.2 or large journal SB Chevy 2.100 rod journal sizes and good set of rods, steel or aluminum and then the best custom pistosn you can get with .043,.043, 1/16 oil rings set up for a vacuum pump, no gapless rings The B1 heads and top end parts you have now will rev to 8500 RPM pretty easily with all the other good proper parts to do that, if your willing to do that then buy the good parts now while every thing is still in good shape I have a new high nickel cast iron 4.500 bore size Koleno block and a set of B1-MC heads with Ti intake valves that I am planning on building a 555 C.I. bracket motor with a old used Sonny Bryant top fuel forged steel fully counter weight 4.375 stroke crankshaft with BB Chevy rod journal sizes and all new parts to achieve near 1000 HP on E85 fuel with a single large dominator carb., or maybe two 1050 CFM Dominator carbs on a sheet metal tunnel ram on E85 if needed
Re: stroker kit
[Re: Stanton]
#2467191
03/16/18 02:03 AM
03/16/18 02:03 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
NO! Just bite the bullet on price and get real American parts. Bryant, Callies, Crower, ect... JE, Ross, Diamond and ICON ca get you the right piston.
Re: stroker kit
[Re: Biginchmopar]
#2467277
03/16/18 12:09 PM
03/16/18 12:09 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
NO! Just bite the bullet on price and get real American parts. Bryant, Callies, Crower, ect... JE, Ross, Diamond and ICON ca get you the right piston. . This for sure!!!
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: stroker kit
[Re: Biginchmopar]
#2467510
03/16/18 09:36 PM
03/16/18 09:36 PM
Posts: 1,111 Usa
A39Coronet
Usa
You won't find a kit. B1 heads have a different valve angle than say Indy's or Trick Flow, so there are no shelf pistons available. Plus, the amount of power that the B1 heads can produce are more than what most "Economic" rotating assemblies can handle. You are going to want some good parts in that combo. And I'm sure Diamond or any major piston manufacturer has, or has the ability to create, these valve angle pockets. He won't be the first to run B1s I'm sure. NO! Just bite the bullet on price and get real American parts. Bryant, Callies, Crower, ect... JE, Ross, Diamond and ICON ca get you the right piston. 440 Source has trouble centering a crank seal in a timing chain cover...so I don't trust them with rotating assemblies in the slightest.
Re: stroker kit
[Re: A39Coronet]
#2467520
03/16/18 10:00 PM
03/16/18 10:00 PM
sgcuda
The OP asked about a stroker kit. The point is that there are no "in stock" pistons that will work with a B1 cylinder head. Any company can cut some pistons. But he shouldn't trust a salesman looking to make an end of the week quota that tells him something like they are "Universal Fit" or "They Fit All Wedge Heads".
Re: stroker kit
[Re: sgcuda]
#2467532
03/16/18 10:24 PM
03/16/18 10:24 PM
Posts: 20,160 PA.
pittsburghracer
When you build combos with higher cubic inches there are so many ways to get where you are going. My 572 combo I put together in 2009 had a set of Indy pistons cut for 440-1 heads. I then had them cut for B1’s also. It had a stock length 440 rod in it. The 572 I am building now has a 7.150 rod in it. I see lots of used pistons out there but you won’t find many on the shelf. It doesn’t take that long to get a set of custom pistons made
Re: stroker kit
[Re: sgcuda]
#2467534
03/16/18 10:26 PM
03/16/18 10:26 PM
Posts: 1,111 Usa
A39Coronet
Usa
The OP asked about a stroker kit. The point is that there are no "in stock" pistons that will work with a B1 cylinder head. Any company can cut some pistons. But he shouldn't trust a salesman looking to make an end of the week quota that tells him something like they are "Universal Fit" or "They Fit All Wedge Heads". So then OP shouldn't order a stroker kit through a Jegs or Summit hotline. If he calls Ohio Crank, they will piece together a kit with what he needs, by working with trusted and proven vendors. I doubt Diamond or any major dealer is going to risk their reputation to meet an imaginary quota. Diamond gives you one profile modification for free. It's not uncommon to have to get non-standard pistons. These are cylindrical slugs with relief cuts...not a space shuttle engine. You said it yourself..."any company can cut some pistons".
Re: stroker kit
[Re: moparmatt0]
#2469769
03/21/18 03:44 PM
03/21/18 03:44 PM
Biginchmopar
Carson City, Nevada
I decided to stay at 499 ci and ordered rods from manley and pistons from icon thanks for all the help Matt. ICON knows all about B1 Heads, ask for Daniel.
