Converting 67 GTX to disk brakes #2465845
03/13/18 04:10 PM
03/13/18 04:10 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I'd like to convert my 67 GTX to front disk brakes using original parts, not aftermarket. I'm familiar with doing this conversion on A-bodies but haven't done it on a B-body before. I'm hoping to find someone selling the complete assemblies but wasn't sure if I will need to find a set that includes upper and/or lower control arms or not. Will I need to change the upper and/or lower control arms for this conversion?
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2465907
03/13/18 05:58 PM
03/13/18 05:58 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just the spindles, if you're going to us all factory parts
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2465928
03/13/18 06:43 PM
03/13/18 06:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
There are some aftermarket kits that offer factory reproduction components as well as OEM components for a factory type install, or you can hunt for vintage OE parts, used, new, rebuilt, NOS...
you need to decide early on if 67 period correct is your goal or larger factory updated components are desired? that way you can be pointed in the direction you seek
Mike
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2465936
03/13/18 06:57 PM
03/13/18 06:57 PM
John_Kunkel Offline
John_Kunkel  Offline
Re: Converting 67 GTX to disk brakes [Re: DAYCLONA] #2466134
03/14/18 12:13 AM
03/14/18 12:13 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
"you need to decide early on if 67 period correct is your goal or larger factory updated components are desired? that way you can be pointed in the direction you seek"
67 period correct is how I would like to do it.
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2466141
03/14/18 12:29 AM
03/14/18 12:29 AM
BDW Online content
BDW  Online Content
If you have 15" rims why go through the trouble and only put 10" disc on when 11" disc is available?
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2466382
03/14/18 02:32 PM
03/14/18 02:32 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
The 67 disc parts are hard to find.
Re: Converting 67 GTX to disk brakes [Re: dynorad] #2466482
03/14/18 05:12 PM
03/14/18 05:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2467307
03/16/18 01:02 PM
03/16/18 01:02 PM
dynorad Offline
dynorad  Offline
OK I guess easy to find but at crazy prices.
I have a 67 hemi GTX and I used brakes from a '69.
Re: Converting 67 GTX to disk brakes [Re: dynorad] #2467394
03/16/18 04:46 PM
03/16/18 04:46 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I would give doc diff a call. He can set you up with everything you need.
He also will ask tell you which stock booster to use if you want power brakes.
Re: Converting 67 GTX to disk brakes [Re: rapom] #2467427
03/16/18 05:49 PM
03/16/18 05:49 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
https://www.ebay.com/itm/Bendix-Mopar-4-...th/232611985151
There's always ebay, if you haven't looked, before you asked.
But, $$$$$$$$$$$
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2468135
03/18/18 03:46 PM
03/18/18 03:46 PM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
I used a-body spindles from the early 70s; the 10" rotors (including bearings & seals), calipers w/ pads, 15/16th master cylinder for disc/drums all from early 70s b-bodies . Biggest expense was getting custom hoses from Dr. Diff; very nice units, worth the price. Cost me about $200-250. Did this conversion about 12 years ago. Works nice; parts are easy to buy for maintenance. For me, this is as close as I'll get to factory style disc brakes for a '67 GTX.
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2468136
03/18/18 03:51 PM
03/18/18 03:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
if factory stock is your only desire ,,,then your only option is seek out the original 1967 thru 1969 parts.
Not an easy task by any means , but definitely do able with time and effort on your part
ANY other option I would use the later model A body stuff
Re: Converting 67 GTX to disk brakes [Re: gtx6970] #2468162
03/18/18 05:00 PM
03/18/18 05:00 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What's wrong with the 70/74 E, and 71/72 B body stuff?
Re: Converting 67 GTX to disk brakes [Re: 440mopar] #2469309
03/20/18 07:09 PM
03/20/18 07:09 PM
Brookeville, Md
Mr.Yuck Offline
Not enough dumb comments...yet
Mr.Yuck  Offline
Brookeville, Md
I'm using a set off a 74-75 A-body. Cheap and bolts right on.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
Re: Converting 67 GTX to disk brakes [Re: 71birdJ68] #2469344
03/20/18 08:10 PM
03/20/18 08:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Nothing, bolts right on, just that the calipers are 2 pin/single piston, the 70-2 E/B will use the 2 piece rotor, the 73-4 E use the unicast rotor, OP wants to stay with 67 OEM
Re: Converting 67 GTX to disk brakes [Re: DAYCLONA] #2469373
03/20/18 09:10 PM
03/20/18 09:10 PM
BDW Online content
BDW  Online Content
Can you see difference with rim on?
