Re: turning piston diameter down
[Re: LSP]
#2468641
03/19/18 04:27 PM
03/19/18 04:27 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
I would say all if not all NASCAR engine builders turn their own pistons. No, the only team turning any pistons is Hendrick. Really?
[Re: cudaman1969]
#2469127
03/20/18 02:18 PM
03/20/18 02:18 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
I would say all if not all NASCAR engine builders turn their own pistons. No, the only team turning any pistons is Hendrick. Really? Last I heard couple years ago. A place called Combustion Technologies was roughing their billets, then finished in house. Childress tried to, then gave up. Most are on Mahle or Pankl these days. Designing/making pistons not as easy as it sounds, the machining and inspection equipment is spendy.
[Re: LSP]
#2469159
03/20/18 03:02 PM
03/20/18 03:02 PM
cudaman1969
fredericksburg,va
U I would say all if not all NASCAR engine builders turn their own pistons. No, the only team turning any pistons is Hendrick. Really? Last I heard couple years ago. A place called Combustion Technologies was roughing their billets, then finished in house. Childress tried to, then gave up. Most are on Mahle or Pankl these days. Designing/making pistons not as easy as it sounds, the machining and inspection equipment is spendy. Maybe just the tops then
