Re: Steel lower rad hose, Big Block [Re: 6bblgt] #2465424
03/12/18 09:33 PM
03/12/18 09:33 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By 6bblgt
if you can't maintain temperature & it is exceeding your thermostat rating - the excellent flow & open thermostat may not allow the fluid to spend enough time in the radiator to cool
so then, why when a car is running hot, do you " race" the engine, thereby speeding up flow? wouldn't you want it to idle, so the coolant spends more time in the radiator?
Re: Steel lower rad hose, Big Block [Re: terzmo] #2465428
03/12/18 09:36 PM
03/12/18 09:36 PM
jersey
jersey
Originally Posted By terzmo
I have a 472 hemi in a 67 R/T that runs cool in hot weather in traffic and down the road for what I say are short high speed runs. At 65 to 70 mph the temp will rise over 200 (slowly) if kept at the speed. Slow to 50-55 and the temp will go down. Alum rad with stock waterpump. I'm thinking a problem "could" be the lower hose collapsing at higher RPM. Does anyone use a non stock rigid or flex metal lower hose ?
what's your timing?
what carb?
Re: Steel lower rad hose, Big Block [Re: Spaceman Spiff] #2465713
03/13/18 12:32 PM
03/13/18 12:32 PM
moparx  Offline
see thread in the race section. "time in the radiator" is an old wives tale. you need coolant flow, air flow, plus adequate radiator size to maintain cooling parameters.
Re: Steel lower rad hose, Big Block [Re: terzmo] #2466704
03/15/18 12:28 AM
03/15/18 12:28 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Watching this thread as I have the same issues with our big blocks.
People saying YES thermostats 50%, people saying NO thermostat %15 and people saying cut the guts out of the stat %35 .
We have run with the guts cut out, too hot and just run without a thermostat and still too hot, trying the 180 thermostat soon even though some say it will not help.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Steel lower rad hose, Big Block [Re: Spaceman Spiff] #2467044
03/15/18 07:57 PM
03/15/18 07:57 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
what's your timing?
what carb?
Holley 950 double pump
12 at idle..36 at high speed
Re: Steel lower rad hose, Big Block [Re: ns1aar] #2467512
03/16/18 09:41 PM
03/16/18 09:41 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
car runs strong to 130+ but heats up like first stated
Re: Steel lower rad hose, Big Block [Re: terzmo] #2467552
03/16/18 11:07 PM
03/16/18 11:07 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
terzmo, Is your timing ALL in at 65mph ? Maybe it is not full advance at the RPM your sitting on ?
1971 Barracuda
Re: Steel lower rad hose, Big Block [Re: terzmo] #2467917
03/17/18 11:44 PM
03/17/18 11:44 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Anyone know if those super coolants or water wetters work at all? I went with a larger radiator, no issues under any conditions.
Re: Steel lower rad hose, Big Block [Re: moparx] #2468154
03/18/18 04:39 PM
03/18/18 04:39 PM
Minn
SportF Offline
SportF  Offline
Minn
This is one of my 3 most favorite myths though. Neat thing about it is that it will NEVER go away.
