Bushed lifter bore question #2461789
03/06/18 12:38 AM
03/06/18 12:38 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
In a BB, how are solid lifters lubricated when the bores are bushed ?
Re: Bushed lifter bore question [Re: varunner] #2461808
03/06/18 01:03 AM
03/06/18 01:03 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Drill a small hole in the bushing.
Doug
Re: Bushed lifter bore question [Re: varunner] #2461812
03/06/18 01:07 AM
03/06/18 01:07 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
If they're already installed, is splash enough ?
Re: Bushed lifter bore question [Re: varunner] #2461814
03/06/18 01:09 AM
03/06/18 01:09 AM
New York, USA
Chargerfan68 Offline
New York, USA
As doug said, i had my machinist put .030” holes on the bushings for a little oiling. But mine is a race application only, so it mostly gets splash oiling. I would never depend on only a .030” hole for any street application , but thats just me. I could barely see tha .030” holes. I actually thought he forgot to drill them until i looked real good for them. Thats how small they are.
Re: Bushed lifter bore question [Re: varunner] #2461815
03/06/18 01:11 AM
03/06/18 01:11 AM
New York, USA
New York, USA
Is it only race? Any street or extented idling at all?
Re: Bushed lifter bore question [Re: varunner] #2461873
03/06/18 03:34 AM
03/06/18 03:34 AM
Solid lifters or solid roller lifters?
If solid roller they should have a oil hole in the oil gallery into the bushing, .030 to .090 depending on the shop doing the work shruggy If not rollers no need for any other oiling twocents
I need to go pickup my 400 block now after having bushings installed in it to seal the oil galleys up at max lift with the Comp Cams solid roller lifters set up for pushrod oiling, that shop put a .060 oil hole in the bushings up I had assembled the motor and primed it and found out it only had 20 Lbs. of oil pressure with the comp lifters, I swapped them to a set of regular Cranes solid rollers I had in the cabinet and had zero oil pressure with them shock whiney
This motor has a set of Jesel paired shaft rockers hence the need for pushrod oiling shruggy
Onwards and upwards wrench grin
Re: Bushed lifter bore question [Re: varunner] #2461903
03/06/18 09:57 AM
03/06/18 09:57 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
These are solid lifters, race only. I gave them a lifter dia. to hone to, I'm going to measure the bores and I hope I have at least .0015" clearance, .002" would be better.
sounds like you're having fun Cab.
thanks
Re: Bushed lifter bore question [Re: varunner] #2461915
03/06/18 10:48 AM
03/06/18 10:48 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
My 505 is bushed with BHJ bushings and was honed to size for the Comp-AMC EDM lifters.
I did nitride the cam as well.
Think like a .030 hole to lube the lifter.
It's been running since 2012 with a .600 flat tappet since then.
I have over 5,000 street miles, highway, idling in 90*+ weather.
I weekly bracket race with it as well.
And something around 100 passes going 11.'0s @ 120-121
Have fun !
Re: Bushed lifter bore question [Re: varunner] #2461994
03/06/18 01:58 PM
03/06/18 01:58 PM
Canada
RobR Offline
RobR  Offline
Canada
I've been bushing blocks since the early 80's..BHJ fixture..I run cast bushings and I've used splash only on the street and also a .030 to .050 hole no real difference in wear with the cast..
In the late 70's I tried bronze for the half dozen or so engines with splash only and when it came to freshen there were some that needed to be replaced..
Mickey at BHJ told me to try his cast bushings and I've never used bronze after that...very good service life with cast on the street..
Re: Bushed lifter bore question [Re: varunner] #2462008
03/06/18 02:27 PM
03/06/18 02:27 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I wonder why a cast bushing would be recommended. cheaper ? doesn't matter anyway, if it works, you're good. proper clearance is probably the main thing. thanks all
Re: Bushed lifter bore question [Re: RobR] #2462031
03/06/18 03:31 PM
03/06/18 03:31 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I switched bronze bushing manufacturers, ( got away from BHJ) and they look much much better long term, and hone nicer. Just my experience.
RIP Monte Smith
Re: Bushed lifter bore question [Re: varunner] #2462038
03/06/18 03:49 PM
03/06/18 03:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
With the amount of oil being slung around in an engine, I wouldn't add 16 .030 oil leaks unless I had pushrods oiling the top end. .030 is a huge hole when there's 60 or 70 PSI behind it. I oiled a complete top end with bushed rockers at 7400 through a .045 jet with a minimum amount of wear showing. Bushed lifter bores and oil to the cam bearings restricted as well. Hundreds of runs at 7400. My goal was to minimize the amount of oil flying around doing nothing but getting aerated and get it onto the crank.
Re: Bushed lifter bore question [Re: varunner] #2462689
03/07/18 05:40 PM
03/07/18 05:40 PM
dogdays Offline
dogdays  Offline
IF you're talking about CAST IRON then the answer is simple. The carbon flakes in the cast iron provide some lubrication.
However, just about any metal and most ceramics can be cast so it's just an assumption that you're talking about cast iron.
R.
Re: Bushed lifter bore question [Re: dogdays] #2462736
03/07/18 07:33 PM
03/07/18 07:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I ran undrilled bronze bushings on the street w/ solid flat-tappet lifters and saw definite wear patterns and extra clearance in the bushings. The late Dan Costello lent me a fixture to add holes to them, so I added .125" holes before I switched to solid roller lifters.
Everyone who hears the size of those holes always acts shocked and tells me they're way too big. Well, they're a He11uva lot smaller than the size of the galley opening in an unbushed lifter bore, and the engine had no oil pressure issues on the dyno either at idle or WOT up to 7200 RPM.
Re: Bushed lifter bore question [Re: varunner] #2462751
03/07/18 07:59 PM
03/07/18 07:59 PM
fast68plymouth Offline
Solid flat tappets in a race only application?
If the clearance is right....... You're good without the holes.
Re: Bushed lifter bore question [Re: dogdays] #2462838
03/07/18 10:39 PM
03/07/18 10:39 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
R.
I think you mean graphite flakes not carbon
Re: Bushed lifter bore question [Re: BradH] #2463101
03/08/18 02:32 PM
03/08/18 02:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
One of the reasons for bushings is to eliminate those huge oil leaks. I didn't have oil pressure issues either, looking at the gauge. But my rod bearings sure appreciated it when I started fixing the internal leaks.
Re: Bushed lifter bore question [Re: CMcAllister] #2463284
03/08/18 07:44 PM
03/08/18 07:44 PM
BradH Offline
BradH  Offline
I understood the oil control benefits. My concern was the bushing wear from street use w/ splash-only lubrication. If I bush my other block (and I'd like to), I won't go as big on the oil feed holes... probably .060".
Re: Bushed lifter bore question [Re: BradH] #2463486
03/09/18 12:49 AM
03/09/18 12:49 AM
I picked up my 400 block from the machine shop in Vancouver, WA this afternoon, they put lifter bushings in it with .060 holes in them ,according to them work It is to late to unload it tonight due to cold, ice in the drive way and my old cautious age grin
I'll unload it tomorrow morning and get it into the assembly room and take a good hard look at it after cleaning it thoroughly and putting it on a engine stand, again.
Hopefully the low oil pressure issue is gone and it lubricates through the pushrods properly with better oil pressure luck
More info on this later when I'm done thumbs
Re: Bushed lifter bore question [Re: varunner] #2463809
03/09/18 03:48 PM
03/09/18 03:48 PM
Locomotion Offline
Locomotion  Offline
If I remember correctly, the Direct Connection oil galley tube kit for a small block didn't say anything about holes for added oiling. Just peening the tube in each lifter bore on one side. Apparently with solid lifters, there is enough "splash" to provide enough lube. (I did it once - never again!)
Cam/lifter lubrication would be my biggest concern. But a little bit more through a small lube hole couldn't hurt with a flat tappet.
