Re: Would pushrod length make this much difference?
[Re: BradH]
#2448199
02/07/18 09:13 PM
02/07/18 09:13 PM
hemi-itis
Pushrod oiling is the answer to anything that has an issue with burnt cups.
[Re: BradH]
#2448280
02/08/18 12:35 AM
02/08/18 12:35 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Your pics don't give the minute differences justice.
Longer pushrod equals more max lift while a shorter pushrod gives quicker more mid lift but with less max lift.
Significant difference??, in the scheme of the whole overall lift event, either way, long/short pushrod, doesn't make any significant difference in performance on the engine involved. The valve train, does like the longer pushrod though, less stress on the rocker arm because of the lesser angles involved. IMO
[Re: BradH]
#2448310
02/08/18 01:47 AM
02/08/18 01:47 AM
Posts: 4,206 New York
polyspheric
The minimum adjuster length isn't a specific number of turns. What matters: 1. no contact throughout the range of travel 2. enough adjustment to get lash
Boffin Emeritus
[Re: BradH]
#2448348
02/08/18 04:37 AM
02/08/18 04:37 AM
Posts: 43,126 Bend,OR USA
I've seen adjusters and pushrod cups broken off due to using to short of pushrods, way to short To long can and may beat up the bottom of the rockers also so my choice is to see between 1/8 of a thread to three complete threads max exposed under the rocker arms As already mention on the single shaft T&D system they like 1 1/2 turns out to three turns out max on their adjusters for oiling the push rods properly I think I have 1 1/2 threads exposed on my 440-1 with the Jesel pair shaft system with pushrod and spray bar oiling
[Re: Stanton]
#2448629
02/08/18 06:13 PM
02/08/18 06:13 PM
BradH
The lobe lift only changed because I reversed-engineered the lobe lift for the same valve lift to account for the ratio change. If I'd left the lobe lift the same, then I'd have had to increase the lift curve on the valve side. It was simpler to leave the rest of the rocker diagram the same and only tweak the pushrod adjuster arc to match the ratio difference.
[Re: Stanton]
#2448661
02/08/18 07:42 PM
02/08/18 07:42 PM
Be a good excercise with the rocker on the head, an adjustable pushrod, a checking spring, and a dial indicator.
[Re: BradH]
#2449070
02/09/18 01:08 PM
02/09/18 01:08 PM
Posts: 216 America
WedgeFED
America
[Re: Cab_Burge]
#2449182
02/09/18 06:41 PM
02/09/18 06:41 PM
Posts: 4,457 Washington
madscientist
Washington
I wonder if these instructions apply to stud mounted rockers only? Nope. Adjuster position affects geometry on stud and shaft rockers.
