spark plugs ? #2436711
01/18/18 03:06 AM
01/18/18 03:06 AM
Illinois
sixbbl 69 Offline OP
Illinois
69 440 six bbl with mopar performance alum heads.525 hp pump gas. what type and number plug should i start with for first start up.
Re: spark plugs ? [Re: sixbbl 69] #2436712
01/18/18 03:07 AM
01/18/18 03:07 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
stock '69 440+6 plugs
Re: spark plugs ? [Re: A/MP] #2436714
01/18/18 03:11 AM
01/18/18 03:11 AM
Illinois
Illinois
J11Y won't fit the heads.
Re: spark plugs ? [Re: sixbbl 69] #2436719
01/18/18 03:48 AM
01/18/18 03:48 AM
Washington
madscientist Offline
Washington
RC9YC champion
Use a 12 if it's under 10:1
Re: spark plugs ? [Re: sixbbl 69] #2436911
01/18/18 04:20 PM
01/18/18 04:20 PM
Do you know the compression ratio and octane rating you will use?
I have a 505 C.I. 440 block that has right at 10.08 to 1 compression and I'm going to use Champion RC12YC on our local pump swill. I've had other pump gas motors with a little more compression, 10.78 to 1, that I used champion RC9YC and Autolite AR3911 non resistor race plugs and AR3910 non resistor race plugin them with good results up
I went out to the shop and got couple of other Autolite resitor street pump gas plugs, 3924 and maybe 3925, which is hotter, if they make that plug number now scope
Good luck, let us know what you use and your results scope
Re: spark plugs ? [Re: sixbbl 69] #2437750
01/20/18 12:08 AM
01/20/18 12:08 AM
Illinois
Illinois
thanks Mad and Cab
