Re: 426 Hemi Intake Manifold Bolt Locations
[Re: earlymopar]
#2436803
01/18/18 01:05 PM
01/18/18 01:05 PM
Posts: 2,632 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
A 65 Race Hemi takes allen bolts with a captive washer. You will find out why later. Mopar still sold those recently. Someone will have them in stock. They b pricey.
2011 Drag Pak Challenger
[Re: earlymopar]
#2436837
01/18/18 02:02 PM
01/18/18 02:02 PM
rickseeman
Stuttgart, Arkansas
Sorry, I had to go do something. Anyway, the allen bolts have a "captive" washer (I believe they call this a Simms washer). If you tried to use regular bolts and studs that use a flat washer this might end in a very bad way. On most of the bolts you are working thru the little holes. Won't be long before a washer falls off as you are taking the bolt out and you know where it's going. Bad day. But if you use the proper bolts, the washer is captive and the whole thing won't go in the cylinder. Mo better. It is best to torque the intake with the book instructions. (I know, nobody does it that way.)
[Re: earlymopar]
#2437152
01/18/18 10:53 PM
01/18/18 10:53 PM
Posts: 10,706 North Dakota
6PakBee
North Dakota
Not to hijack but if someone has a picture of the '67 arrangement I could use that.
[Re: CrazyD]
#2437680
01/19/18 09:44 PM
01/19/18 09:44 PM
Posts: 1,335 Oregon
earlymopar
[Re: dragon slayer]
#2438009
01/20/18 05:06 PM
01/20/18 05:06 PM
Posts: 4,179 California
mickm
California
I think there is documentation that disagrees with above. The longest W should be on the rear driver side where the throttle linkage connects. That medium Y goes where the W is shown. Do not believe there is any reason to have an over side stud in the location shown above. Was thinking the same thing. Where the white bolt is listed on the passenger side, there is no boss, and nothing bolts on there. I believe that is correct, it belongs on the rear drivers side and is one of the bolts that holds down the throttle linkage.
