Re: AVS is sinking floats
[Re: cbusters]
#2437521
01/19/18 03:44 PM
01/19/18 03:44 PM
Posts: 1,151 Cruising!
QuickDodge
Cruising!
You may not have any problem other than the float bowls being dry. A lean air / fuel mixture can cause an engine to back fire through the intake. (A rich mixture will be through the exhaust.) With the float bowl being dry, the mixture is likely to be lean while the float bowl is filling.
If it was my car, I would very carefully check out the ignition system to make certain there is not an ignition problem as well. It is entirely possible the car has two problems. Gasoline burning inside the carburetor is not good!!
[Re: dartgame]
#2437536
01/19/18 04:05 PM
01/19/18 04:05 PM
Posts: 2,252 New York
rarefish
It’s been said a bunch of times above - you’ve got some sort of timing issue if it backfires. Make sure your timing marks are correct on the damper, use a positive stop on piston #1.
I’m lazy, and decided not to install an electric fuel pump. What I do when my dart sits and the gas in the avs evaporates - is I take a small amount of gas (about a 1/4 cup) and pour it into the fuel bowls through the bowl vents. Then it starts immediately ! The only vent on a AVS that I know of is the one that is on the driver's side. It is fairly easy to add fuel to that side, but how do you add fuel to the passenger side bowl? Can it be done?
[Re: rarefish]
#2437963
01/20/18 02:56 PM
01/20/18 02:56 PM
Posts: 9,826 MI, usa
dvw
MI, usa
I’m lazy, and decided not to install an electric fuel pump. What I do when my dart sits and the gas in the avs evaporates - is I take a small amount of gas (about a 1/4 cup) and pour it into the fuel bowls through the bowl vents. Then it starts immediately ! The only vent on a AVS that I know of is the one that is on the driver's side. It is fairly easy to add fuel to that side, but how do you add fuel to the passenger side bowl? Can it be done? The holes right next to the metering covers. Doug
[Re: cbusters]
#2438013
01/20/18 05:12 PM
01/20/18 05:12 PM
Posts: 8,393 Highland, MI.
Sunroofcuda
Highland, MI.
Back in the 70's & 80's, the only carbs that would go dry after just a few days were GM Rochesters in my experience. You could only start GTO's after priming the carbs - it was maddening. NEVER had a Mopar with an AFB, AVS, or Thermoquad go dry - even after sitting for a month. My '71 Hemi Charger could sit all winter & it would fire in the spring after pulling the choke, a few pumps to the floor & a little cranking.
[Re: dvw]
#2438323
01/21/18 12:00 PM
01/21/18 12:00 PM
rarefish
I’m lazy, and decided not to install an electric fuel pump. What I do when my dart sits and the gas in the avs evaporates - is I take a small amount of gas (about a 1/4 cup) and pour it into the fuel bowls through the bowl vents. Then it starts immediately ! The only vent on a AVS that I know of is the one that is on the driver's side. It is fairly easy to add fuel to that side, but how do you add fuel to the passenger side bowl? Can it be done? The holes right next to the metering covers. Doug Doug, Is this the spot to fill the passenger side bowl?
