Re: 70 Cuda side marker bezels
[Re: gregok]
#2435047
01/15/18 04:04 PM
01/15/18 04:04 PM
Posts: 1,058 Dallas, Texas
FC7cuda
Dallas, Texas
642 is right rear 632 is right front 643 is left rear
You can test fit them before install to confirm.
68 Charger 70 Cuda
[Re: FC7cuda]
#2435071
01/15/18 04:42 PM
01/15/18 04:42 PM
Posts: 702 Oklahoma
gregok
Oklahoma
Do you know the number then to the left front bezel as looks likes that is the one I need to find? also, what is the best way to polish the lens on theses and the taillight ones?
[Re: moparmarks]
#2435189
01/15/18 08:28 PM
01/15/18 08:28 PM
Posts: 6,342 SE PA.
QuickBpBp
SE PA.
70-1 Fury rears are the same part number as Cuda fronts. They might be the same part number but The 70-1 Cuda uses studs to mount all 4 markers. The 70-1 Furies rear use phillips head screws and screws into the retainer....
[Re: QuickBpBp]
#2435224
01/15/18 09:32 PM
01/15/18 09:32 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
70-1 Fury rears are the same part number as Cuda fronts. They might be the same part number but The 70-1 Cuda uses studs to mount all 4 markers. The 70-1 Furies rear use phillips head screws and screws into the retainer.... The Fury fronts have screws. The rears had studs. I've used Fury bezels on a 71 Cuda so I know they fit.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2435237
01/15/18 09:49 PM
01/15/18 09:49 PM
Posts: 6,342 SE PA.
QuickBpBp
SE PA.
70-1 Fury rears are the same part number as Cuda fronts. They might be the same part number but The 70-1 Cuda uses studs to mount all 4 markers. The 70-1 Furies rear use phillips head screws and screws into the retainer.... The Fury fronts have screws. The rears had studs. I've used Fury bezels on a 71 Cuda so I know they fit. Sure they "fit" but they are not correct. All the front Fury ones I have had studs like Cuda. The Rears have the screws through the retainer plate due to the fact studs would hit the Quarter extensions and could not put a nut on them..... These were removed a few weeks ago from an 1970 Fury still wearing the original paint and all the other sets I have removed have been the same on Furies...The red are the rear ones and the Amber in the front have the studs...
[Re: gregok]
#2435248
01/15/18 10:14 PM
01/15/18 10:14 PM
moparmarks
Your right. I have it backwards. Been a few years but I used to pull all the ones I could fine in the yards. The Fury front bezel will fit and has the same number as the Cuda rears. I use to have a big box of Cuda and Fury fronts. Backing plate is the same too. The socket housing and lens fits Cuda front.
[Re: moparmarks]
#2436457
01/17/18 06:05 PM
01/17/18 06:05 PM
Posts: 702 Oklahoma
gregok
Oklahoma
Thanks for the help! anyone have a spare 3403633 bezel they would sell?
