What street tire are you using #2433692
01/13/18 12:27 AM
01/13/18 12:27 AM
A727Tflite Offline OP
Wondering what some of you are using on a 67-69 B Body for front tires on the street.
Limited use at the track - good for mid 11's.
Plan to use them on 4.5 inch wide wheels.
Radial design 15".
Thanks.
Re: What street tire are you using [Re: A727Tflite] #2433700
01/13/18 12:42 AM
01/13/18 12:42 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I've run Mickey Thompson Sportsmans for years, they are bias-plies though. I just switched over to some Firestone Redlines last year.
Me personally, I have three different toys, two of them have radials. I've also mixed and matched radials with bias-plies in the past too. I like all of them. Everyone complains about bias-plies pulling you all over the road but, I don't notice too much difference from my radial cars when driving on the same roads.
Re: What street tire are you using [Re: parksr5] #2433728
01/13/18 02:10 AM
01/13/18 02:10 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Bias are great when they are new. They just don't keep that new as long as radials do.
Re: What street tire are you using [Re: A727Tflite] #2433815
01/13/18 11:26 AM
01/13/18 11:26 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
We've used 205/75 x 15 generic radials on two cars. One runs 123, the other close to 140. The amount of time spent at speed is very little. We are on 5" rim though.
Doug
Re: What street tire are you using [Re: A727Tflite] #2433843
01/13/18 12:32 PM
01/13/18 12:32 PM
Thanks Doug, I want that skinny front / wide back look on my Satellite. Likely work towards that on the 62.
Re: What street tire are you using [Re: A727Tflite] #2434284
01/14/18 05:05 AM
01/14/18 05:05 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I have used either Cooper Cobras or Mickey Thompson Radial ST's on my Bee. But neither were as skinny as you are wanting to go.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: What street tire are you using [Re: A727Tflite] #2434299
01/14/18 07:53 AM
01/14/18 07:53 AM
P
Porter67 Offline
Porter67  Offline
P
One my slower car a drag radial hooks fairly well on the street, on my sprayed street racer I buy a pair of MT 28x12.5 bias each year. They dont hook the best but dont blow off like a drag radial does but they are consistent and predictable but as mentioned when they wear, at lest mine get to looking like the tread is pulled and sponge like and dont hook as good as when newer.
For plain street rubber that just is for driving or smoking Radial T/A or as mentioned the cobra tires seem like a good pick.
Re: What street tire are you using [Re: A727Tflite] #2434321
01/14/18 11:14 AM
01/14/18 11:14 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have heard the cheap brand "Primewell" are a pretty soft good street radial. I will be having to find a good highway tire this year and might give them a try. I started running a pro bracket radial slick not he track and I am trying not to drive on the street with them as much to make them last longer.
68 Barracuda Formula S 340
Re: What street tire are you using [Re: A727Tflite] #2435357
01/16/18 12:59 AM
01/16/18 12:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Well my car is a 63 B-body but I use these 15 x 6 Torque Thrust with a street radial tire that's 215/70R-15 up front. They are not a race tire but since I street drive it it 99% of the time I wanted a street tire up front. The car has run 10.70's using these tires up front. I did not want a skinny drag tire up front on my street car so thats why I use what I do. Ron
Re: What street tire are you using [Re: A727Tflite] #2435386
01/16/18 01:32 AM
01/16/18 01:32 AM
Thanks Ron - 👍
