Re: Leaky transfer case
[Re: larrymopar360]
#2436526
01/17/18 08:24 PM
01/17/18 08:24 PM
Posts: 15,831 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I have run thru a couple cans of brake clean. I will continue to clean it up. So much crud built up from years of neglect. The leaking freeze plug at rear of engine (that I replaced as soon as I got truck) for years that kept everything underneath wet, collected tons of dirt, along with the other leaking fluids.
Thanks Mike. Sending my number now.
Facts are stubborn things.
[Re: scratchnfotraction]
#2437057
01/18/18 08:30 PM
01/18/18 08:30 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
you can use some purple cleaner and scrub brush then rinse with water save the brake clean to remove the oil film when done.
Thanks. I have been using some Simple Green too, along with a paint scraper, it's just hard to get on top and in the little nooks and crannies. I think bottom line is I'm going to have to pressure clean the layers of neglect away.
