Smallblock Turbo Manifolds Hitting Ebay #2431594
01/09/18 02:09 PM
01/09/18 02:09 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
I seen in the past week these hitting ebay, china built but dont look to bad and one set was priced at $500 buy now and another set started at $50, probably go for $250.
They look to be fabbed by the same folks dong the small tube stainless headers that are pretty decent.
I asked another supplier and it looks soon to be a full twin turbo china kit coming to market for around a grand.
Might be fun if one subs the turbos for good ones.
https://www.ebay.com/itm/DODGE-MOPAR-Twin-Turbo-Manifolds-Headers-T4-T3-318-340-360-LA-5-2L-5-9L-MAGNUM/253346830320?fits=Make%3APlymouth%7CModel%3AVolare&hash=item3afca5d7f0:g:WM4AAOSwXf1aTo63&vxp=mtr
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2431630
01/09/18 02:55 PM
01/09/18 02:55 PM
Granbury TX
Prochargedmopar Offline
Granbury TX
Ha,
I was just fixing to post this.
Buy it now is at $450 atm.
I see bidding on a pair with 3hrs to go at $170.
The “kit” has been out about a month. Was $2000 until last week they drpped it to
$1749
I asked last month if they sold only headers and they said no.
But today I just saw the above.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F253203705631
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2431742
01/09/18 06:56 PM
01/09/18 06:56 PM
Granbury TX
Granbury TX
Sold:
$325
02 Mercedes C230K
19 Camry
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2431836
01/09/18 09:29 PM
01/09/18 09:29 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Where were these when I was looking for a set.
Had to fab up a set on my own.
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: moparborn] #2431907
01/09/18 11:06 PM
01/09/18 11:06 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
give me the suppliers name and number please
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: cesar perez] #2431951
01/10/18 12:07 AM
01/10/18 12:07 AM
Granbury TX
Granbury TX
Follow the link above and then msg. the seller.
Or this one: EWORLDSALES1
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F352244829804
02 Mercedes C230K
19 Camry
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2431994
01/10/18 12:55 AM
01/10/18 12:55 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Open the box, throw away the gaskets, and install.
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2432011
01/10/18 01:30 AM
01/10/18 01:30 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Those look interesting.
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2432064
01/10/18 03:46 AM
01/10/18 03:46 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
those look like they make make doing a turbo kit hard... both manifolds are identical. how the tubes come off the flange... then the collector faces down- until you mount the other side and it is UP!
id like to see it for a 440 though- id deal with crap angles and generic made!
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2432206
01/10/18 02:46 PM
01/10/18 02:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's what I was thinking: 2 right-side headers...
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: topside] #2432437
01/10/18 08:43 PM
01/10/18 08:43 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
The head flanges are different. I wonder why one header is upside down
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2432455
01/10/18 09:22 PM
01/10/18 09:22 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
They are just trying to show both the top and bottom. The flanges need to go in opposite directions if you are using common tangential exhaust housings. Using on-center exhaust housings would make one side high and the other low. This is assuming you are using two turbochargers.
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: TRENDZ] #2432543
01/10/18 11:54 PM
01/10/18 11:54 PM
Granbury TX
Granbury TX
I started wanting some sb turbo manifolds in the late 90’s after playing with a turbo z 2.2l.
I’m amazed after all these years nobody has mass produced some decent manifolds.
That Fahler guy is making ONE and I do me ONE style of manifold for LS powered trucks and he is backed up 6mo.
Even though he has massive competition from tricky performance, Hooker, and many others.
Pretty trippy.
When I retire in 2 years I’m going to build log and shorty tube headers from shedule 10 stainless.
Have both types for B and A bodies.
Big and small block.
Of I can find a junk E body engine bay I could build both styles and engines for those too.
What’s that?
12 different manifolds total?
Something to fiddle with in the garage and then see who wants one. lol
02 Mercedes C230K
19 Camry
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2432806
01/11/18 02:33 PM
01/11/18 02:33 PM
polyspheric Offline
polyspheric  Offline
A well-sorted example of the "headers look good, but the results are disappointing": all the 1,000+ HP LSX engines out there using the original truck manifolds.
Same is true for up to about 700 HP on the Toyota 183" 2JZ engine: a cast manifold is really close to the hand-fab $2,500 header, and lasts 10 X as long. Mine is made by SPA in Brazil.
What else favors cast instead of tube?
1. much lower underhood temperature
2. less lost heat energy reaching the turbine inlet
Boffin Emeritus
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: polyspheric] #2433009
01/11/18 08:45 PM
01/11/18 08:45 PM
Granbury TX
Granbury TX
Totally agree.
This is why I am building me a semi-log style patterned after
the LSx factory manifolds and making them out of schedule 40.
Just gotta get my compression whoas’ figured out.
02 Mercedes C230K
19 Camry
Re: Smallblock Turbo Manifolds Hitting Ebay [Re: Porter67] #2433020
01/11/18 09:04 PM
01/11/18 09:04 PM
IL
furious70 Offline
furious70  Offline
IL
yup, I used these rather than build [img]https://photos.app.goo.gl/sTCVZUHQ0DeinkFI2[/img]
70 Sport Fury
68 Charger
69 Coronet
72 RR
