Re: 71 340 exhaust manifold bolts
[Re: 5carguy]
#2428524
01/03/18 10:11 PM
01/03/18 10:11 PM
Posts: 306 Georgia
69bfan
Georgia
AMK Products out of Winchester, VA. Part Number C-8023.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: 5carguy]
#2429336
01/05/18 04:52 AM
01/05/18 04:52 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I'm the original owner of a '69 Barracuda 340 that I ordered in the fall of '68. Recently I removed the manifolds for the first time and took photos. Factory was 2 thick conical washers at the front and 2 at the rear with no washers in the middle 2 places. So yes, four washers on each side and no washers on the inner two bolt locations.
These photos are left side: front, middle, middle, and rear. Right side is the same as far as conical washers.
And AMK is the best source. AMK has actual size color photos of each item they sell, so you know exactly what they offer. Items that are exact copies of Mopar fasteners are coded with the pentastar logo and show the Mopar part number. Others who sell fastener kits are mostly just re-selling AMK.
[Re: Dibbons]
#2429662
01/05/18 10:44 PM
01/05/18 10:44 PM
Posts: 306 Georgia
69bfan
Georgia
The AMK kits are retailed through some vendors and then there are similar kits that put together from a variety of parts that I feel are not of the quality of the OEM parts. So just try to determine what your purchasing to avoid any frustrations.
[Re: 69bfan]
#2429766
01/06/18 02:50 AM
01/06/18 02:50 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Those cone washers are getting hard to find
Abe Lincoln
[Re: Dibbons]
#2429872
01/06/18 12:51 PM
01/06/18 12:51 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I don't recall the factory using gaskets. Doesn't mean they didn't though. My guess, the heavy solid center section stays put, but the long thinner arms to the outside would be more prone to expansion and movement.
[Re: 5carguy]
#2435463
01/16/18 04:55 AM
01/16/18 04:55 AM
kentj340
Cut and Shoot, TX
340 exhaust manifold gaskets from the factory: driver side had the heat shield/gasket. Passenger side - no gasket.
Concerning the thick conical washers on 340, there were 4 on the driver side but only 2 on the passenger side. Photos above are the left side showing 4. Photos below are the right side showing only 2, front, middle, rear.
[Re: 5carguy]
#2435949
01/16/18 10:19 PM
01/16/18 10:19 PM
kentj340
Cut and Shoot, TX
They are recessed quite a bit. Special long bolts.
[Re: 5carguy]
#2437491
01/19/18 02:48 PM
01/19/18 02:48 PM
kentj340
Cut and Shoot, TX
Here's the assortment of 340 exhaust manifold bolts from the factory in order - only 6 thick conical washers.
Top of photo is front, bottom is rear.
[Re: kentj340]
#2437493
01/19/18 02:58 PM
01/19/18 02:58 PM
kentj340
Cut and Shoot, TX
Hundreds of times I have soaked fasteners in vinegar for usually 2 - 3 days, and I usually hand wire brush each day to physically remove rust residue in order to speed up the chemical reaction. Works every time, and the fasteners are then ready for phosphating (Parkerizing) or zinc plating.
These exhaust manifold bolts have minor cosmetic pitting, but are serviceable.
