School Buses
#2421123
12/19/17 08:59 PM
12/19/17 08:59 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I bought a 63 Dodge school bus. I want to use it as a cruiser/tow truck. I’m going to take the body off and mount it on a 96 Ram 3500. The wheel base is with 3”. Any pointer from anybody that has done it before? When finished in hoping it will tow a 20’ stacker trailer. I would also like to do the power tour or follow drag week with it.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: School Buses
[Re: finn]
#2421366
12/20/17 11:13 AM
12/20/17 11:13 AM
65 Hemi
San Diego CA
Thank you for all the input. I will look at the frame width and flatness. I’m just trying to get away from the front straight axle.
Doug
Re: School Buses
[Re: 65 Hemi]
#2433789
01/13/18 09:54 AM
01/13/18 09:54 AM
Posts: 5,778 ohio
ruderunner
ohio
While it might be easier to start with a flat frame, it's not a big deal to make one flat.
The hardest part is going to be supporting the bus body while swapping. It's big and heavy.
Speaking of weight, how much does the bus weigh? What's the gvw? What's the gvw of the donor chassis? Is the tow rating high enough for what you want?
Personally I'd be looking at a newer class 6 chassis.
Angry white pureblood male
