Re: picked up a 1965 Sweptline
[Re: Red383]
#2418489
12/14/17 02:42 PM
12/14/17 02:42 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Fitting headers in that truck could be a problem. The transmission crossmember is usually where most long tube headers would run. There was one company that made a run of long tube headers for Poly Sweptline trucks. I don't know if they are still available but Stan's might have them. http://www.t137.com/dtapoly.bak/addpoly.phpThere were 2 other companies that made long tube headers for 67-68 trucks with the LA and big block. One was Hedman and I don't remember the other one.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Red383]
#2418535
12/14/17 04:38 PM
12/14/17 04:38 PM
Posts: 15,831 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It's great that TTI makes Headers for the Poly 318 because TTI has quality stuff (you do pay for the quality). It would be nice if you can fit them to your truck and stick with the 318. But if not, I still say a stroked 400 would be the big block way to go.
Facts are stubborn things.
[Re: Handygun]
#2421099
12/19/17 08:17 PM
12/19/17 08:17 PM
dogdays
Very nice truck. Really clean and straight. Yes it's the first series 1965 which has a 122" wheelbase instead of a 128. That 6" of wheelbase makes a difference in towing. The 128 is more stable. The in-cab fuel tank has to go. There is a better place for a fuel tank, like in the rear where the spare tire might go. There are also spaces along the framerails that might be useful.
Even though the truck is a stock color, which was from time to time called Turf Green, duffers will try to convince you the truck is Forest Service Green. But what do they know?
Here are some sore spots on this cab style: 1. Fuel tank, already mentioned. If it leaks or cracks, you're swimming in gasoline. 2. Door latches. These are a major pain in the bum. They have an aluminum star wheel and it is not reproduced. These are like car latches from the fin cars. Vintage Power Wagons used to reproduce them, but not for 10 years or more. When my star wheel wore out I had to cobble a workable latch from a rear drivers side latch from around a '59 car. 3. The hood hinges wear out and the hood sticks up at the rear. Nice thing about the hood is that it opens up wide enough that you can pull the engine without removing the hood. If your hood hinges work OK, keep them lubed. 4. The truck bed is single wall. That means that any dent that gets put on the inside shows on the outside. I had a crankshaft roll and bang! 5. The tailgate is supported by chains which bang on the body in rough going. 6. Wheelwells are not in the usual places in the bed so a "regular" mat won't fit. That bed is an odd duck. 122" wheelbase strikes again! 7. I've had trouble with the taillights. Also no backup lights. 8. Fortunately the front turn signals are easy to find on Ebay. 9. The brake and clutch master cylinders are basically the same unit, with exception of the residual pressure valve on the brake master cylinder. It sure would be nice to have a dual braking system. 10. Good luck getting power steering.
Now on to the frame: Unless you are used to trucks of the '40s and '50s you will need to do a bunch of studying. This truck is set up with four point mounting for the engine/transmission. There are two mount points near the front like "normal". There are two mounting points on the bellhousing. The crossmember that the bellhousing mounts to is massive and sits right in the way of any non-custom header's collector. The transmission hangs off the back of the bellhousing. Emergency brake is a drum on the transmission. The rear axle has no provisions for emergency brakes, at least not on the 1/2 ton. The hydraulic clutch slave cylinder on the passenger's side of the bellhousing is directly in the way of any noncustom header tube. The bellhousing wraps around the flywheel in such a way that you cannot remove it before removing the engine. It weighs about 72 lb. It should have bolt patterns for flathead 6, slant 6 and A engine. You cannot pull the engine and transmission out of the front of the truck. You remove the transmission first, either through the cab or down to the ground, then the engine will come up and out the front. The frame is set up for a front sump oil pan.
Now we get to the engine. The 318 Poly is NOT larger than an LA engine, physically. It just looks that way. It has the same deck height and bore spacing. Crankshafts are the same. That means that 340 stroker cranks just drop in. Rods are the same. Oil pump is the same. Distributor is the same. What is NOT the same is pistons, camshaft, cylinder heads and valvegear, intake manifold, exhaust manifolds. IF you like to feed the weirdness you can build a big Poly motor. But it will cost you big bucks. There are about five intake manifolds that are not 2-barrel. None of the intake manifolds is currently available for less than $500.There is the Edelbrock P-600 3-2s, usually Stromberg base, the 2-4 barrel Fury manifolds, currently less expensive but take two carbs, the single 4-barrel stock intake, running around $600 last time I checked, the 7503 Weiand, not available new and usually getting around $500, and then the new one that currently retails for $670 or so, if they are actually making them. Camshafts are limited to regrinds except that Camcraft has a bunch of new cores, $185 apiece, but then you have to get the core ground, so I think we're looking at $300+ for a brand new cam. Regrinds of stock cams are not too bad at under $150. Because the valves are in different places on a poly than on a Wedge, pistons are at least semi-custom. Sealed Power makes stock pistons in their antique line but I think they're about $400 a set.
Don't get me wrong, I like the Poly because it's weird. My engine was a stocker with Weiand 7503 and Holley 570 Street Avenger. I used a Direct Connection electronic distributor kit and finished off with dual exhaust. My truck got an honest 16mpg with a lot of rejetting of the carb because I live at altitude. The Poly heads are actually better than the 318 heads and the Poly in near stock trim has more power than a LA 318.
I swapped to a 1986 roller cam 318 and used the 360 hydraulic roller cam and a 1975 or so stock 360 four barrel intake with the 570 street avenger. I used the late model exhaust manifolds with the old exhaust system and picked up 6 mpg right off the bat. Put that in your Poly and smoke it!
If I was doing a ground-up reconstruction I'd look seriously at a GIII Hemi, take #200 off the front end and make steering easier. A B/RB will bolt in and a B makes more sense for room especially as you can build them to 500 inches or more. I didn't think the engine bay looked empty when I substituted the LA for the A. One last thing,,,,,The NP420 transmission has only synchronizers in 3rd and 4th gears.
R.
[Re: dogdays]
#2421549
12/20/17 07:27 PM
12/20/17 07:27 PM
Soopernaut
Des Moines IA
The transmission hangs off the back of the bellhousing. Emergency brake is a drum on the transmission. The rear axle has no provisions for emergency brakes, at least not on the 1/2 ton. R. The star wheels are being reproduced. The same guy can get you stainless steel lined brake and clutch master cylinders. I can re-build your door latches at $200.00 EA with new star wheels made of aircraft alloy aluminum. E-mail me or call at 651 653 0147 I also have new strikers. John cjlapham44@gmail.com CPP makes a power steering kit for this truck. The 65 and later trucks had a provision for emergency brakes on the rear axle. It was no longer on the rear of the transmission on light trucks.
[Re: dogdays]
#2421979
12/21/17 07:21 PM
12/21/17 07:21 PM
Posts: 1,629 OH
Red383
OH
Thanks for all the info Dogdays, I was already aware of most of it though. Yes, the color is Turf Green. This truck actually has three gas tanks with a selector valve on the driver's side floor. It has an extra tank in front of each rear wheel, that you would fill from the inside of the wheel well. see pic. (I'm just glad it had this style, instead of the others you see that have holes in the side of the bed to fill the aux. tanks.
The original owner towed a fifth wheel around the country with this 122" wheelbase truck. Scarey!
The Driver's side door latch "star wheel" is junk and needs replaced. I guess I'll be looking for one of these.
My hood hinges are in good shape and the hood closes/lines up real good, so I will lube up the hinges to keep it that way.
Headlights are the only lights on the truck that work.
I replaced the clutch master and rebuilt the brake master. I still have no brakes, I think it's rust in the lines, but at least I can start it and pull it in and out of the shop. Emergency brake stops it for now. Seems like the brake pedal swing arm needs lubed up, the pedal doesn't want to come back up when pressed.
My emergency bake is on the rear axle brakes, not on the back of the trans.
I've been doing some research on the Poly engine, and havn't made a decision on what I'm going to do long term for drive train. I needed to replace the passenger side exh manifold gasket, and I am attempting to remove three broken studs right now. Are just the top bolts in the water jacket, or are all of them? Want to make sure I put sealer on the correct ones.
Soopernaut, who is this guy? "The star wheels are being reproduced. The same guy can get you stainless steel lined brake and clutch master cylinders."
I saw some info about the CPP power steering, but I'll decide on that after I get it driving on the road. Manual steering never bothered me in my 70 Cuda.
Thanks again for the info guys.
[Re: Red383]
#2422099
12/21/17 11:49 PM
12/21/17 11:49 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Really sweet looking truck. [quote=Red383] For the engine, I’m looking for opinions on which direction I should go. I kind of like the look of the wide 318 that is in there, but is rebuilding it a good option? Parts availability? Are headers and intake manifolds available?[quote] I like the idea of the old poly. A rebuild is no more difficult than any later V-8. I believe the shortblock is the same. Might be want to see if a stroker kit would work. There is some progress being made with Hot Rodding the Poly. https://search.yahoo.com/search?p=polysuperpac.comDon't know about headers but the motors are getting some LOVE. I've read a few articles in "Chrysler Power" magazine, [quote=Red383] Emergency brake stops it for now. Seems like the brake pedal swing arm needs lubed up, the pedal doesn't want to come back up when pressed.[quote] I just went through this with my 77 van. It was the rubber hoses had gone soft insde and would act like a flapping rubber valve to keep the fluid from returning unless I manually pulled the pedal back up. Not a bad idea to replace all the brake components including the lines. Not too hard a job and well worth the effort. The split rims gotta go. They are considered to be dangerous. I doubt you could find someone to mount anything on 'em. I am no help in finding replacements. I used 18"X 8" aftermarket wheels. Great tire availability. Your not going to find "new" tires in the 16.5 size.
[Re: Red383]
#2422246
12/22/17 10:55 AM
12/22/17 10:55 AM
Soopernaut
Des Moines IA
Soopernaut, who is this guy? "The star wheels are being reproduced. The same guy can get you stainless steel lined brake and clutch master cylinders." He is John Geidl aka PowerwagonJohn. He doesn't visit computer forums much, is not a member here and prefers to do business by phone or email. He has been in the Dodge truck hobby for a very long time.
