70 B body Windshield gasket #2417191
12/12/17 04:10 AM
12/12/17 04:10 AM
Pa.
Tek52 Offline OP
Tek52  Offline OP
Pa.
Can someone with experience tell me, who makes the best molded front windshield gasket for a 1970 B body Mopar? By this I mean quality,ease of installation, good fitment, etc.
(Reason I ask here is, "everyone" seems to make the "best" gasket.Just ask them. lol)
Thanks!
Paul
Re: 70 B body Windshield gasket [Re: Tek52] #2417253
12/12/17 11:44 AM
12/12/17 11:44 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Gotta make sure that when you have the windshield installed, that the glass shop puts butyl along bottom of opening and up the sides (about 6-8") BEFORE the rubber goes on and windshield into the rubber . . . any other way, guaranteed to leak !!! Don't let the glass shop tell you otherwise . . . that is way the factory did it and FSM says to install too !!!
To answer your question, not sure who I got for the 70 Sport Satellite . . .
Cheers
Mark
Re: 70 B body Windshield gasket [Re: Tek52] #2417415
12/12/17 04:12 PM
12/12/17 04:12 PM
Pa.
Tek52 Offline OP
Tek52  Offline OP
Pa.
Thanks Mark! I recall now, my car had butyl sealant in the area you describe. Question... the butyl sealant is used between the windshield glass and gasket,
What seals the gasket to the body flange? Use butyl there too? I seem to remember sealant there too.
Paul
Re: 70 B body Windshield gasket [Re: Tek52] #2417561
12/12/17 08:38 PM
12/12/17 08:38 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Paul
Sealant only between the gasket and the body, apply it along the entire bottom channel and approx 8-12" from the bottom of the A pillar channels upward in the A pillar channels, you only need a 1/4" bead in the 90 degree fold of the channel, apply this bead just before you set the gasket in place and install the windshield immediately, there's NO SEALANT in the gasket's groove/channel/lockbead where the glass fits
FYI if your looking for a good gasket that fits, Legendary is where I purchased mine over years, they were NOS units, I don't know if they still have NOS in supply, worth a try if your willing to spend a little more
Mike
