Car is quickly wearing out Green bearings on one side?
#2416186
12/10/17 02:34 PM
12/10/17 02:34 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I'm running an 8 3/4 rear end, cleaned inside thoroughly, Torsen diff w 3.91's, Moser axles & Dr Diff econo disc brake kit.
I'm getting a noisy passenger side bearing again after only a few thousand miles. I changed both bearings the last time I had this noise, and it was quiet for 3-4 thousand miles. Gear oil is filled to proper level.
I'll check the axle runout at the flange this week. Would a bent housing cause this?
Re: Car is quickly wearing out Green bearings on one side?
[Re: jbc426]
#2416222
12/10/17 03:13 PM
12/10/17 03:13 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Obviously it's not the bearing, as it's a repeat occurrence, the bearing is suffering the results from another cause/component... What were the wear/failure points of the bearing in question... If your returning the same rim/tire to that side of the axle have you checked it for run out on and off the vehicle How's the bearing's dry fit in the axle housing before being assembled on the shaft, bore show any signs of the bearing spinning/galling?
[Re: jbc426]
#2416256
12/10/17 03:53 PM
12/10/17 03:53 PM
Posts: 43,124 Bend,OR USA
Probably isn't helping the bearing if the housing is bent Check it with a couple of carpenter squares, one on each side with a helper and a tape measure and measure as far out as you can to the front and rear and then up and down from the flanges I bent a early B body housing pretty badly in my old pump gas Duster, the axles (originally the left side and then the passenger side got really bad the more I raced it :shock ) where really hard to slide in, I had to use a block of wood and a hammer to drive the passenger side in before the right side ladder bar bracket finally broke off Do both of your axles slide in okay? Let us know what you find
[Re: hemirdrnnr]
#2416410
12/10/17 09:17 PM
12/10/17 09:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Just wondering are Green bearings made for street use or for track use? both...
[Re: hemirdrnnr]
#2416423
12/10/17 09:40 PM
12/10/17 09:40 PM
Just wondering are Green bearings made for street use or for track use? Probably designed for drag racing only back when originally designed and sold OP, I put a set on a Dana 60 rear end years ago (1970 35 spline axles) that was driven on the street and the inner retainer came loose and let the axle slide out of that bearing until the tire touched the outer wheel lip Same thing happened to another Dana 60 that was in a drag race only car at the track Both of those where the first type Green ball bearing axle bearings for Mopars offered back in the mid 1970s, I have sold, installed and used the newer ones like Dr. Diff sells now with no more problems The early ones had the retainer molded onto the bearings, the later, better, ones don't The retainer is not captured on the bearing and the later ones have a retainer ring on the outer bearing race on the axle end to locate the bearing in the housing on all the newer ones I've used in both 8 3/4 and Dana 60 regardless of axle size or spline count
[Re: jbc426]
#2416464
12/10/17 10:22 PM
12/10/17 10:22 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Would a bent housing cause this? Yep, but a factory bearing would most likely forgive the bend.
[Re: buildanother]
#2416936
12/11/17 08:11 PM
12/11/17 08:11 PM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
Don't overlook the axle being slightly bent. A bent axle would cause a vibration and that green bearing is being shaken to death. It wouldn't take much.
[Re: dogdays]
#2417376
12/12/17 03:18 PM
12/12/17 03:18 PM
jbc426
West Coast, USA
I likely called the diff the wrong name. It is in fact, a TrueTrac.
I'm elbow deep in upgrading and rebuilding the front end of my pick-up, but will check out everything using the tips suggested above.
Thank you to all those who offered suggestions and techniques to figure out what is going on. I very much appreciate your knowledge and time to post. I'll post the outcomes of the inspections as soon as I can get to it.
[Re: jbc426]
#2417405
12/12/17 03:57 PM
12/12/17 03:57 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
There can be a problem with the 8 3/4 true trac, the side gear on some have a lot of play in them allowing the axle to move a lot, it can wipe out the green style bearing, jack up car & grab the wheel top & bottom, see if you can move the wheel, ie slack.
[Re: CSK]
#2422518
12/22/17 11:58 PM
12/22/17 11:58 PM
jbc426
West Coast, USA
There can be a problem with the 8 3/4 true trac, the side gear on some have a lot of play in them allowing the axle to move a lot, it can wipe out the green style bearing, jack up car & grab the wheel top & bottom, see if you can move the wheel, ie slack. Exactly! This is what Cass was telling me this morning. I was on the phone with him for 1/2 an hour. I grabbed the wheel at 3 & 9 o'clock and it moves as if the wheel is turning left and right. I hope putting in one of Cass's new Blueprinted Suregrip diff's eliminates this wheel bearing issue and leads to the elimination of the high speed vibration I have been experiencing for the last several years. The driveline is smooth as silk until 95 mph and then a serious resonating vibration begins and increases with speed. It resonates through the entire car. My pinion angle is optimum, tires balanced and I thought I would never figure this out.
