Shock setting for transbrake
#2416091
12/10/17 07:49 AM
12/10/17 07:49 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
Ok finally get my new transmission this week , i hope 🤔. Nah should be good . Anyway what if any change in rear shock adjustment should i think about ? Currently footbrake no 2 step . I do run radials , 28x10.5r15 pro bracket radials @16 1/4psi . I have Viking Crusader rear shocks , dbl adjustment and radial valving . I have Caltracs . Shocks are 10 from softest compression and 5 from softest on extension I am hoping to get down towards a 1.45 sixty . Best currently is 1.47 with national event track prep , 1.48/.49 normally
Tex
Re: Shock setting for transbrake
[Re: tex013]
#2416478
12/10/17 10:39 PM
12/10/17 10:39 PM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
As someone was known to say on here, "tighter is faster".
[Re: CMcAllister]
#2416508
12/10/17 11:23 PM
12/10/17 11:23 PM
tex013
Sydney,Australia
As someone was known to say on here, "tighter is faster". huh ? Tex
[Re: tex013]
#2416598
12/11/17 01:38 AM
12/11/17 01:38 AM
tex013
Sydney,Australia
Kool thanks Dave . I only have 1 video of a launch in slomo .it does show some tyre sidewall wrinkle on the hit , so I will try some tighter ext I know all the still shots show wrinkle .
Tex
[Re: tex013]
#2416663
12/11/17 05:56 AM
12/11/17 05:56 AM
tex013
Sydney,Australia
Thanks guys Rebel i think i might need more omph to go where you do. Dave , car seems happiest at this psi . I did start at 18.5 same as in Hoosier and et street radials i used to use . This new motor wanted the new Viking rears and lower pressure to hook up . So it will need some testng
Tex
[Re: tex013]
#2416904
12/11/17 06:47 PM
12/11/17 06:47 PM
tex013
Sydney,Australia
thanks for the input guys
Tex
