Re: 727 Rear Clutch Upgrade worth it?
[Re: Hot 340]
#2418810
12/15/17 01:20 AM
12/15/17 01:20 AM
Posts: 3,069 Michigan
A727Tflite
Too cold for me to go to the garage again and I don't want to get snow on my pink slippers but .623 sounds pretty skinny. EDIT - sorry - thought that was your measurement. Mayberry I should have enlarged your image of the mic. 👀
[Re: A727Tflite]
#2418811
12/15/17 01:23 AM
12/15/17 01:23 AM
Posts: 3,395 Pa
Hot 340
Pa
Too cold for me to go to the garage again and I don't want to get snow on my pink slippers but .623 sounds pretty skinny. Stay warm. Those two numbers 623 and 824 are the last 3 numbers in the part numbers. The thickness of both are around .785ish.
[Re: A727Tflite]
#2418916
12/15/17 11:22 AM
12/15/17 11:22 AM
Posts: 3,395 Pa
Hot 340
Pa
Only explanation I can come up with is Kokomo machined the late casting to the early spec. Maybe they ran out of service parts for the early application - stranger things have happened there. I can image. I bought a dirt cheap, new old stock A1 Transmission hp rebuild kit the other day because it has the solid front red band, but it also has a brand new, early bellville in it. Temping to just use it.
[Re: Hot 340]
#2419110
12/15/17 05:49 PM
12/15/17 05:49 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
From the factory TF Service Bulletin, running changes for the '74 model year:
"Neutral to Drive shift quality
A-727 only
The N-D package for the A-727 also required the following changes in the rear clutch. The Belleville spring has a higher load and a reduced cone height and thickness. In the clutch retainer, the Belleville spring seat and cushion ring groove were moved forward. The over-all height of the piston was also increased. The piston and Belleville will not service prior models. The clutch retainer will service prior models."
[Re: John_Kunkel]
#2419131
12/15/17 06:51 PM
12/15/17 06:51 PM
Posts: 3,395 Pa
Hot 340
Pa
A-727 only
John, I believe you. And I believe my measuring tools as well..
[Re: Hot 340]
#2419139
12/15/17 07:10 PM
12/15/17 07:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Take both parts back to your supplier shop and see if you got a bad part.. sounds like both parts are the same
[Re: MR_P_BODY]
#2419173
12/15/17 08:54 PM
12/15/17 08:54 PM
Posts: 3,395 Pa
Hot 340
Pa
Take both parts back to your supplier shop and see if you got a bad part.. sounds like both parts are the same Just gonna mail it back to the ebay seller.They're a trans parts dealer...they can measure it.😂
[Re: FurryStump]
#2419180
12/15/17 09:11 PM
12/15/17 09:11 PM
Posts: 5,987 Anoka County, MN
Leigh
Anoka County, MN
I have found a couple sources for the later belleville spring anyone have a source for the later piston? Cancelled part#. Used, is your best bet.
[Re: John_Kunkel]
#2419190
12/15/17 09:29 PM
12/15/17 09:29 PM
Posts: 3,395 Pa
Hot 340
Pa
A-727 only
Moving forward with the discussion on this upgrade...per John's post of the service bulletin, Do I need to do somthing to the piston retainer as there appears to be changes made there as well for the '74-up parts. How about the plastic cushion spacer? Is it the same or do I need 74-up specific one?
[Re: Hot 340]
#2419204
12/15/17 10:03 PM
12/15/17 10:03 PM
A727Tflite
We went from metal to plastic on the spacer, they are interchangeable. The piston retainer is the part with the clutch splines, also called a rear clutch piston support. I don't recall a change to it in 74. The clutch retainer is what fits around the piston support and that is what had the groove location change made to it in 74. As the bulletin states it is interchangeable. If you can - you might try to add another snap ring to the one just up from the spacer, it makes the retainer tight to the support if you find yours is sloppy.
As for the retainer - a retainer out of a 46/47/48 will fit the 727.
