Re: 360 leaks water from lower timing cover bolt
[Re: 70FJ5383]
#2413488
12/05/17 10:54 AM
12/05/17 10:54 AM
Posts: 14,889 up yours
Supercuda
I would not use RTV, Teflon tape is better. It will seal and it will keep the bolt from corroding itself solid tot he block.
[Re: Supercuda]
#2413496
12/05/17 11:11 AM
12/05/17 11:11 AM
X2, I would use some thick cement like permatex #2 or Indian head shellac.
[Re: Supercuda]
#2413529
12/05/17 12:56 PM
12/05/17 12:56 PM
Posts: 2,915 Calgary, Alberta Canada
a12rag
I would not use RTV, Teflon tape is better. It will seal and it will keep the bolt from corroding itself solid tot he block. X2 . . . teflon tape the bolt . . .
[Re: dvw]
#2414147
12/06/17 12:58 PM
12/06/17 12:58 PM
Agreed (on the leak potentially being nearby). I would drain the coolant & screw in an NPT "tank valve" (less than $3 at O'reillys) into the cooling temp sensor port at the top rear of the block & with shop air pump it up to 15 lbs & see if it holds. You can spray a soapy water solution around potential areas to see if it starts to bubble (for external leaks) & there is a "bubble up" (iirc) solution that reportedly bubbles more readily but the dish soap in some water has worked for me. EDIT on second thought I would pump it up to just 10 for a start.
[Re: Joesixpack]
#2415422
12/08/17 09:31 PM
12/08/17 09:31 PM
Have same problem with bolt above timing tab, went to tighten it Which bolt (hole) in particular is that?
[Re: Joesixpack]
#2416940
12/11/17 08:22 PM
12/11/17 08:22 PM
those lower threads on the aluminum timing cover are a weak 11/16" deep & open on the back side & go directly into the timing chain area/eng oil & it uses a 3/8 bolt so I'm thinking if you could block the very back with something fairly firm just to temporarily plug the rear end of that passage for your work then drill/tap a good amount of the threads then carefully/lightly blow the chips out the front (the critical part) & I would use brake kleen as opposed to shop air & either helicoil or just drill/metric tap to the next larger metric size/use a metric bolt. Use grease on the tap to catch alot of debris. EDIT Another option might be to permanently JB weld a stud in there
[Re: Joesixpack]
#2419811
12/17/17 12:52 PM
12/17/17 12:52 PM
I wouldn't think you would need to go to all that trouble (helicoiling undamaged threads). I think the one thread just went bad (they are aluminum) & after this you will be OK. Just me I'd clean em (& the bolts) & use some sealer & call it good.
[Re: 70FJ5383]
#2419835
12/17/17 01:30 PM
12/17/17 01:30 PM
Supercuda
Putting in helicoils in a timing cover on the bench isn't a lot of effort. doing it while the timing cover is installed in the vehicle is another story.
