Junk yard crank trigger? #2391397
10/22/17 07:39 PM
10/22/17 07:39 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I built a crank trigger some years ago for a 440 but in the end I had to buy an aftermarket "brain" to be able to set the parameters. I don't remember where I found it or the manufacturer and I don't care because it was expensive and I like to be cheap.
Is it possible to find something useable on a junk yard? Wheel and sensor you can buy anywhere, but the rest?
I'm not going EFI, I just want an excellent ignition that sparks exactly where it should
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Junk yard crank trigger? [Re: HP2] #2391404
10/22/17 07:46 PM
10/22/17 07:46 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
go find a ford edis setup. they use 36-1 trigger wheels as well as good sensor that can be rigged up and mounted just about on any engine. if not check out our mopar specific crank trigger kits for small block and big blocks $275 and you don't have to spend day at the junkyard and fabbing parts that may not work.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Junk yard crank trigger? [Re: HP2] #2391796
10/23/17 02:10 PM
10/23/17 02:10 PM
AndyF Online content
AndyF  Online Content
I don't think you'll find a crank trigger for a Mopar in a wrecking yard. If you are using a MSD ignition then the only thing you really need to buy is the pickup. If you are handy with tools you could fabricate the mount an the trigger wheel. You need to find the right magnets and install them with the correct pole orientation.
If you want a MSD setup for cheap I have a used wheel and sensor that I don't need anymore. You would need to fabricate your own mount. I've switched most of my stuff over to EFI so I have some left over MSD crank trigger stuff sitting around.
Re: Junk yard crank trigger? [Re: HP2] #2392763
10/25/17 05:51 AM
10/25/17 05:51 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
Just ordered a Megajolt Lite https://wiki.autosportlabs.com/MegaJolt_Lite_Jr.
and then a Ford Edis-8 module complete with coils on ebay for $75. A friend had a trigger wheel for $20 so all I have to buy now is the pickup.
I will get a fully programmable crank trigger ignition for less than $300 plus a little fabrication!
Maybe I have missed something but I don't see any advantages with MSD.
I will get fully adjustable timing curve, rev limit and also vacuum advance. Even datalogging is possible.
71 Duster 340
