rebuilt 440 and cannot get vac on cooling system. #2391157
10/22/17 12:09 PM
10/22/17 12:09 PM
Omaha
road Offline OP
road  Offline OP
Omaha
Cannot get a constant vac on cooling system before putting coolant in it. Radiator and heater core test fine. New pump impeller. Can only get vac to around negative 8.
Should i just fill with water and see what happens or any suggestions before that step.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: road] #2391159
10/22/17 12:11 PM
10/22/17 12:11 PM
Andrewh Offline
Andrewh  Offline
I have never heard of pulling a vac on the cooling system.
since it is meant to be under 12 to 16 pounds of pressure, I have to ask what was the point?
Some items may not hold pressure /vacuum if they were designed for the opposite.
if you put it under 10 pounds of pressure, does it hold?
Re: rebuilt 440 and cannot get vac on cooling system. [Re: road] #2391173
10/22/17 12:25 PM
10/22/17 12:25 PM
RapidRobert Offline
RapidRobert  Offline
Hello Bill. You dont want to fill it with water cuz if the leaking is internal then it will start rusting & must be torn down ASAP but if it is inside & we find it with another method at least we have some time to get after it if we confirm it being on the inside by dry checking. I would get a "tank valve" from O'reillys for less than $3 & with your air chuck & a tire pressure gauge pump the system up to 10 lbs & see if you hear where the leak is coming from & you can squirt some soapy water around the pump & intake manifold and head/block interfaces to see if it bubbles. it is a schrader valve with a 1/8"PT fitting & screw it into the cooling temp sender port on the water pump. EDIT pic added. MORE EDIT if it wont hold vac it wont hold psi as it is a simple sealed system ex for the possible (not sure) complication of the type of rad cap with the loose thin brass "recovery" piece dangling on the bottom. with a "regular" cap if it wont hold vac then there is a problem. I had a weak cap so I put a piece of rubber under it to seal the system when I was dealing with my issue.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: Andrewh] #2391175
10/22/17 12:27 PM
10/22/17 12:27 PM
Supercuda Offline
Supercuda  Offline
That's how the factory filled them and the reason for the lower radiator hose spring.
Don't be the exception.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: Andrewh] #2391182
10/22/17 12:40 PM
10/22/17 12:40 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Very common to pull a vacuum on a cooling system before filling. Especially on the newer stuff, in some cases the cooling/heating tubes are so small in the heater core for insistence it is impossible to purge all the air out of the heater core without a vacuum.
I would try to pump it up and see if you can see/hear where it is leaking next.
Good luck.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: Challenger 1] #2391184
10/22/17 12:46 PM
10/22/17 12:46 PM
Cincinnati, Ohio
Cincinnati, Ohio
It has to be used to fill big truck diesel engines.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: Challenger 1] #2391202
10/22/17 01:21 PM
10/22/17 01:21 PM
RapidRobert Offline
RapidRobert  Offline
If a person does do a wet test, use 100% green prestone antifreeze to keep the ferrous metal from rusting till it does come apart.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: road] #2391292
10/22/17 03:49 PM
10/22/17 03:49 PM
Andrewh Offline
Andrewh  Offline
interesting. learned something new.
it will be interesting to hear where the leak was. Please keep us posted.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: road] #2391419
10/22/17 08:27 PM
10/22/17 08:27 PM
Minn
SportF Offline
SportF  Offline
Minn
Water pump shaft seal probably won't take a vacuum, and its not meant to. Pressurize it instead, maybe 10 psi.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: SportF] #2391586
10/23/17 01:42 AM
10/23/17 01:42 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
There are two valves on a radiator cap, pressure and vacuum.
The vacuum valve is to refill the radiator from the overflow tank when the motor cools and creates a vacuum.
It only takes 2 lbs of vacuum to open the return valve.
Re: rebuilt 440 and cannot get vac on cooling system. [Re: B5 Bee] #2392077
10/23/17 10:35 PM
10/23/17 10:35 PM
RapidRobert Offline
RapidRobert  Offline
I would add the $3 tank valve. pump it up to 10 lbs. See if it drops. If you have a compression tester you could take the hose & remove the schrader valve from it & screw it into each cyl with a balloon sealed on the quick disconnect end & see if it expands as you maintain the 10lbs. spray some soapy water around the freeze plugs & the drain plugs & sparinly on top of the intake manifold to head face(s), both sides and around the pump and pump housing & see if any area bubbles show. holler how it turns out. EDIT If you pump the cyls & if this is a new cam breakin I would undo the rocker arms so the valves are closed/cyl(s) sealed so you dont have to turn the dampener to get each cyl on TDC which will wipe the goop off of the lobes.
