Re: DANA OLD DANA NEW
[Re: A/MP]
#2388694
10/17/17 12:38 PM
10/17/17 12:38 PM
an8sec70cuda
Didn't the Ram SRT-10 trucks have a Dana 60 rear? That's the only Dodge truck I can think of that has used a Dana 60 in the rear for a long time.
[Re: an8sec70cuda]
#2388823
10/17/17 04:32 PM
10/17/17 04:32 PM
dogdays
My online lending library shows no Dana 60s or 70s in use as a rear axle in 2006.
I expect the axle in question is from American Axle and Manufacturing (AAM). They are stout, 10.5 and 11.5 ring gears.
In other years, especially behind Diesels, Dodge'd do hybrid axles like a Dana 80 with Dana 70 ends.
Back to the 2006 axle - you shouldn't be able to break it in stock form. If you convert to semi-floating axles, you can pick which ever ends you want to match the brakes you want. Custom axles don't cost that much. But it only is practical if the gear ratio and differential (limited slip or not) are to your liking. And if it'll fit under your car.
I tend to look under '70s Ford 3/4 ton pickups. They are all over the place and all of them have Dana 60 rears that can be converted for car use. Vans have different setups, many equipped with Dana 61s and semi-floating axles, closer to what you'd see under a car.
A 61 may be the hot ticket if you want to run 3.08s or something like that. Otherwise it isn't worth the effort. The D61 was built for highway gears.
R.
[Re: A/MP]
#2388825
10/17/17 04:37 PM
10/17/17 04:37 PM
an8sec70cuda
The SRT-10 trucks do have Dana 60 rearends. The diesel trucks haven't used a 60 REAR in a LONG time (or ever?), just for the front axle. I know my '01 has a Dana 60 front, but Dana 70 rear.
[Re: an8sec70cuda]
#2388827
10/17/17 04:40 PM
10/17/17 04:40 PM
Posts: 20,159 PA.
pittsburghracer
The SRT-10 trucks do have Dana 60 rearends. The diesel trucks haven't used a 60 REAR in a LONG time (or ever?), just for the front axle. I know my '01 has a Dana 60 front, but Dana 70 rear. HAPPY BIRTHDAY!!!!!!!!!!!!!!!!!!!!!!!!
[Re: pittsburghracer]
#2388886
10/17/17 06:30 PM
10/17/17 06:30 PM
an8sec70cuda
Thanks John!
[Re: A/MP]
#2389188
10/18/17 10:13 AM
10/18/17 10:13 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
From a 2006, it should be the AAM as mentioned. I think they have helical limited slip? I haven't seen one converted for use in the cars, but looks like a nice alternative to the Dana 60. I read in one of the SAE journals about the AAM Quantum axles are making the rear diffs lighter, stronger, and more efficient for the new trucks, but look totally different: https://www.aam.com/media/story/aam-s-ne...ases-efficiency
