Re: Hemi block ID help [Re: AndyF] #2383792
10/08/17 11:39 AM
10/08/17 11:39 AM
E
earlymopar Offline
earlymopar  Offline
E
I just checked the numbers and it's my brother's block so I assume you saw this at Gray's?
- EM
Re: Hemi block ID help [Re: earlymopar] #2383796
10/08/17 11:50 AM
10/08/17 11:50 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Originally Posted By earlymopar
I for one am interested in knowing how you identified this as coming from a specific car. I understand there is a link to the VIN but don't understand how the link is made.
- EM
I had heard of the car before. That makes it easy.
Re: Hemi block ID help [Re: AndyF] #2383801
10/08/17 11:57 AM
10/08/17 11:57 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
- EM
This block matches the description of the block you were telling me about a while back.
Re: Hemi block ID help [Re: earlymopar] #2384078
10/08/17 08:13 PM
10/08/17 08:13 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
- EM
Dan has this special computer that looks like something out of the Gene Wilder version of Willie Wonka and he just puts in any info that’s provided and it spits out the CORRECT answer. 😜 I’m not certain how he does it either but I’ve never caught him in an error.
Re: Hemi block ID help [Re: fastmark] #2384123
10/08/17 09:46 PM
10/08/17 09:46 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Most of it comes right out of his head, have you seen that sucker? laugh2
JB Rhinehart, Realist
A-Body's RULE!
Re: Hemi block ID help [Re: AndyF] #2384162
10/08/17 10:47 PM
10/08/17 10:47 PM
Chicago Blackhawks
H
hemicar1971 Offline
hemicar1971  Offline
H
Chicago Blackhawks
If you have been hanging around smelling a lot of old gasoline and gathering up information on Cudas and Challengers you tend to know were a serial number would fit via your information you have collected. Sometimes the number is known via someone owning a car and asking about if you know of a motor or a body a motor came from. There are a few of these kinds of people doing this for years and it takes time to amass such information off sites and auctions, ebay on and on for years and years. I have been collecting since 1978 still do not have every 1971 Hemi E Body hardtop that was built. The 11-18-68 is the casting date and it went into a 1970 E Body and 11-11-68 usually is a 1971 Hemi Motor Build. First in first out was not used back in the day. I have seen a factory block stamped with .0015 on the Mains. When we rebuild the Hemi motor back many many years ago we had to use another crank that was 10 th. under because we could not find .0015 over size bearing and did not want to cut the hardness from the crank. Motor still running after 30+ years with that crank being changed and the original crank if the car ever get sold will go with it.
