727 not upshifting, wierd pressures
#2383193
10/06/17 10:59 PM
10/06/17 10:59 PM
Posts: 372 Ohio
jensenguy
Ohio
I'm just getting back into a Transmission that I rebuilt years ago, and didn't want to upshift afterwards. Been sitting 5? years. I seem to recall I was not getting any governor pressure at the time.
I took the extension housing off, and sure enough the valve was stuck fast in the governor. I took it all apart and cleaned it up, no debris to speak of inside. Moves freely, put it all back together.
So now, I'm getting into second gear in drive (Can't tell if it is a incredibly soft upshift or starting in second) But not third. I'm doing this on Jack stands so that may be affecting, but getting to 3000 rpm no upshift.
I check my line pressure in Drive at 1000rpm, (again not sure if it is in 1st or second at this point) and see about 100psi line pressure with the thottle lever all the way forward. When I move it all the way back it drops to 85psi or so. I'm guessing this is an internal leak somewhere?
I'm planning on checking Gov. pressure as well, once things cool down.
Re: 727 not upshifting, wierd pressures
[Re: jensenguy]
#2383292
10/07/17 03:45 AM
10/07/17 03:45 AM
Posts: 25,783 Rio Linda, CA
John_Kunkel
I'm doing this on Jack stands so that may be affecting, Jack stands are the absolute worst place to test a transmission's performance. Put it on the ground and check it.
[Re: jensenguy]
#2383495
10/07/17 05:34 PM
10/07/17 05:34 PM
John_Kunkel
Disconnect the TP linkage at the trans lever and see if it shifts through all gears and downshifts at a stop. If it does, the linkage adjustment/installation is wrong.
Which carb? If aftermarket does it have the correct Mopar throttle lever extension?
Re: 727 Governor pressures
[Re: jensenguy]
#2384062
10/08/17 07:40 PM
10/08/17 07:40 PM
John_Kunkel
At a dead stop 2 psi governor pressure at idle in Drive is considered the max allowable.
Other than sticky valves/weights, the sealing rings are usually the source of governor pressure woes.
The throttle lever movement sounds normal; moving the lever aft compresses a spring so the movement would be expected to increase and, near the end of travel, you're in the kickdown detent so the lever resistance increases.
[Re: jensenguy]
#2392451
10/24/17 05:51 PM
10/24/17 05:51 PM
John_Kunkel
Yes, if the front clutch were inop the trans would drop to 1st gear as soon as the band releases on the 2-3 shift. Starting to sound like a stuck 2-3 shift valve in the valve body.
[Re: jensenguy]
#2393105
10/25/17 09:55 PM
10/25/17 09:55 PM
Posts: 8,248 fredericksburg,va
cudaman1969
fredericksburg,va
Got basically same problem in buddy's trans, first time I found the valve body full of dirt and junk. Put another vb in and still no up shift, second time apart front clutches burnt. Let us know all what you find please. Trans was a new rebuild supposely.
[Re: jensenguy]
#2395913
10/31/17 09:59 AM
10/31/17 09:59 AM
Posts: 20,640 in a cattle trailer down by th...
Guitar Jones
Well, if there is nothing obvious in the trans then the debris is most likely coming from the converter and cooler.
