Re: Aftermarket RB Block
[Re: 10sec440]
#2382592
10/05/17 06:48 PM
10/05/17 06:48 PM
Posts: 20,174 PA.
pittsburghracer
I have to laugh out loud when I hear about bad ring seal on aluminum blocks
[Re: pittsburghracer]
#2382995
10/06/17 03:19 PM
10/06/17 03:19 PM
Posts: 43,193 Bend,OR USA
Laugh all you want, I have heard the same results from many heads up west coast racer, power adders included 80 to 130 HP loss(700 + and above HP) on engine combination with all the exact same parts being transferred from a iron block to a aluminum block with or without fill Bottom line now is we have no good source of both types of RB or B block today, aluminum or iron
[Re: 10sec440]
#2385665
10/11/17 03:34 PM
10/11/17 03:34 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Well we run an aluminum block in the heads up car and will take the weight saving ANY day over the minimal HP cost from any minor ring seal issue. We used both and there is a VERY VERY VERY tiny amount of difference in power. More than offset by the lower weight of the block. In fact a new Dart ALUMINUM block was just ordered for it a couple weeks ago as it will be going to a much shorter deck height for next year. Also ordered was another block for a S/G racer for the same reason, the weight. Everything will be transferred from the old 582, rotating assy etc and headed to the dyno. I don't expect to see more than a 5hp difference.
[Re: 10sec440]
#2385680
10/11/17 03:54 PM
10/11/17 03:54 PM
Posts: 14,499 So. Burlington, Vt.
When it comes to a BB Mopar....... I'll take the 150lb weights saving from an aluminum block every time.
[Re: Al_Alguire]
#2386092
10/12/17 02:48 AM
10/12/17 02:48 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
In fact a new Dart ALUMINUM block was just ordered for it a couple weeks ago as it will be going to a much shorter deck height for next year. I assume this is not a mopar block?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: 10sec440]
#2386276
10/12/17 02:06 PM
10/12/17 02:06 PM
Al_Alguire
Las Vegas
Yes a Chevy deal..FWIW I have four engines all with aluminum blocks and wont go back to iron...
[Re: dvw]
#2386745
10/13/17 11:15 AM
10/13/17 11:15 AM
Posts: 784 Liverpool, NY
SILVER67
Liverpool, NY
My car has a very nice late Mega Block, 4.505" with bushed lifter bores. I'd love to have a nice aluminum block. Doug Have the aluminum 4.5 bore version of your iron World block in the basement. Thing can't even weigh 150. Mike
[Re: 10sec440]
#2386816
10/13/17 12:38 PM
10/13/17 12:38 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I have a World cast iron hemi block in the shop and holy crap is that thing a tank!
My KB hemi block is about 140 lbs if I remember right. I'll take the aluminum block all day every day over cast iron.
