Re: Issues lowering my 83 D150
[Re: Dirty did it]
#2176131
10/16/16 04:34 PM
10/16/16 04:34 PM
Posts: 5,960 ohio
ruderunner
ohio
I've heard of this swap but never looked into it myself.
That said, what about swapping in the van steering arms? Iirc their tie rods do go in from underneath, or they may be a different shape.
Angry white pureblood male
[Re: Dirty did it]
#2176179
10/16/16 05:53 PM
10/16/16 05:53 PM
Posts: 14,889 up yours
Supercuda
Not really the wrong board, but more likely to get a valid answer in the truck section is all.
[Re: Dirty did it]
#2176587
10/17/16 12:40 AM
10/17/16 12:40 AM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Welcome to Moparts. I saved this a few years ago because I figured I might do it one day, it might help you out: Lowering a Ram
Mo' Farts
Moderated by "tbagger".
[Re: Dirty did it]
#2178764
10/19/16 08:57 PM
10/19/16 08:57 PM
Posts: 6,018 Salem
Grizzly
Salem
Hey, again thanks: I'll keep going until I hit a wall here......
My first thought is that the D250 truck arms may have been a better way to go, but, please put up a picture or two.
I know nothing about the vans, but the upright steering column and how the steering box and steering linkage is has to be different than the trucks.
I'll wait for your pictures then I'll re-read the old link and try to help some more.
Mo' Farts
[Re: Dirty did it]
#2178799
10/19/16 10:11 PM
10/19/16 10:11 PM
Posts: 5,960 ohio
ruderunner
ohio
Some clarification on the ball joint issue: there are indeed 2 different lower ball joints for trucks and vans. The difference isn't related to which type of vehicle but rather which front suspension package it has. There is a light duty front end and a heavy duty front end. The light duty is found on all halfton and most 34 ton vehicles. The heavy duty is found on most 1 ton and some 3/4 ton. Point Bering,bwhat the badges say is basically irrelevant, even the gvw stickers are iffy. You need to look at the parts.
The quick visual I'd is the tie rods. A long sleeve with 2 short ends is LD. A long inner tie rod with a short sleeve and short outter tie rod ius HD.
Note, pretty sure the truck arms are all flat and van arms have the pocket. Again different arms depending on axle package.
