Trans Cooler Placement #999670
05/25/11 02:17 PM
05/25/11 02:17 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
Where's the best place on the radiator to put a trans cooler, top, bottom, either side?
Re: Trans Cooler Placement [Re: wtucker] #999671
05/25/11 02:21 PM
05/25/11 02:21 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I put mine on the lower half on the front. You still want airflow coming in to the path of the radiator without obstruction. I also moved my license plate out of the way so air currents can come through below my bumper and hit the trans cooler.
I also plumbed mine with 3/8" brake line. The steel line helps cool it down during the flow pattern. Rubber line as some like to do it, or steel braid line hold the temperature in...Its a PITA to bend 3/8" hard line but will last you a lifetime when complete
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
