Re: i want your opinion -- compare my two cams
[Re: 440Jim]
#999645
05/25/11 01:23 PM
05/25/11 01:23 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Although I think the current comp solid could be slightly better, if you keep the rpm limited to 6000 they will be close. But IMO, 440 cubes with ported aluminum aftermarket heads will like over 6000 rpm and that is where I like to cut off using a hydraulic flat tappet cam.
Don't be surprised that the hyd will idle worse and have worse off idle throttle feel (street driving). In my street 440 Cuda I ran a similar size hydraulic, and now the MP 0.557" cam (similar duration to yours, but not as aggressive) and I prefer driving the solid on the street. I ran both with iron adjustable rockers.
I could not agree more.
If you are that tight on the budget,run the hydraulic and save funds for an upgrade later,when you can. Keith
[Re: shoebox]
#999647
05/25/11 03:51 PM
05/25/11 03:51 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
If I had to run a hyd cam the older UD hyd cams are a great choice and I use them in builds for street/strip guys that don't want a solid cam. They are very stable and make good power. I do agree the solid should be slightly better in the low rpms. I'm not sure the solid will run quicker at the track. Sounds like an interesting test.
[Re: shoebox]
#999648
05/25/11 04:48 PM
05/25/11 04:48 PM
Posts: 5,080 organ
maximum entropy
organ
if you're using the stamped rockers with the hydraulic, you'll no doubt lose some lift (they typically check around 1.45:1 or less), BUT, they are very light and very reliable. several thousand years ago i had a 340 street racer, and revved that thing over 7000 daily with an hydraulic cam and the stamped rockers (the heavy duty ones). that engine ran for many years, and i finally sold it (running). i've run solids on the street, too, and they work fine. i think you'd be real close between those cams.
