VooDoo cam in a 318 truck? #998797
05/24/11 12:05 AM
05/24/11 12:05 AM
Seattle Wa
PowerWagonDude Offline OP
Seattle Wa
Has anybody tried Lunati Voodoo cam #60400 in a 318 truck? It is a 1987 2wd Ramcharger with 727 and 3.55 gears, 31 inch tires. Its a daily driver.
Brand Lunati
Manufacturer's Part Number 60400LK
Part Type Camshaft and Lifter Kits
Product Line Lunati Voodoo Cam and Lifter Kits
Summit Racing Part Number LUN-60400LK
UPC 090127605653
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,000-5,000
Intake Duration at 050 inch Lift 208
Exhaust Duration at 050 inch Lift 213
Duration at 050 inch Lift 208 int./213 exh.
Advertised Intake Duration 250
Advertised Exhaust Duration 256
Advertised Duration 250 int./256 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.454 in.
Valve Lift with Factory Rocker Arm Ratio 0.454 int./0.454 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible No
Re: VooDoo cam in a 318 truck? [Re: PowerWagonDude] #998798
05/24/11 12:07 AM
05/24/11 12:07 AM
top-o-the world
RAMIT Offline
RAMIT  Offline
top-o-the world
i had a voodoo in a 440 magnum great cam loved it
Re: VooDoo cam in a 318 truck? [Re: RAMIT] #998799
05/24/11 12:14 AM
05/24/11 12:14 AM
Seattle Wa
Seattle Wa
It is currently a 360 4 barrel that eats gas. I want to install a smaller engine with good torque and road manners. I know a 360 has more torque but i want to get 14-16 mpg. Is that possible??
Re: VooDoo cam in a 318 truck? [Re: PowerWagonDude] #998800
05/24/11 12:24 AM
05/24/11 12:24 AM
top-o-the world
RAMIT Offline
RAMIT  Offline
top-o-the world
with the rite ignition u can gain alot of gas milage i recomend summits brand ignition module and wat kind of carb u running and a carb spacer will get better milage youll notice a big difference
Re: VooDoo cam in a 318 truck? [Re: RAMIT] #998801
05/24/11 12:29 AM
05/24/11 12:29 AM
Seattle Wa
Seattle Wa
It is the stock cast iron Tquad manifold with an aluminum spread bore to square hole adapter and a Holley 600 cfm carb. Free flowing single exhaust with a glasspack.
Re: VooDoo cam in a 318 truck? [Re: RAMIT] #998802
05/24/11 12:30 AM
05/24/11 12:30 AM
top-o-the world
RAMIT Offline
RAMIT  Offline
top-o-the world
the cam would olny make it eat more gas btw
Re: VooDoo cam in a 318 truck? [Re: RAMIT] #998803
05/24/11 03:06 AM
05/24/11 03:06 AM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
the 318 will definitely get better fuel economy over the 360 in different applications. your problems will be, the weight of that RC,the gears,no overdrive,more bulk of the 727 internals,less cubes(with the 318),all will combine to get less than stellar results in fuel economy. you will likely do all that work,and gain 1 mpg, or none.
i mean face it,your not driving a 4-cyl dakota. your driving a big heavy pig,with not-so-highway friendly gears,and a V-8. great mpg's are not looking good........
Re: VooDoo cam in a 318 truck? [Re: superbyrd] #998804
05/24/11 06:59 AM
05/24/11 06:59 AM
Central NC
gch Offline
gch  Offline
Central NC
I don't see that cam being a hog on gas.Short duration and wide lsa should work well.
Lose the holley 600 and go back to the thermoquad if you want mileage.
14 may be doable on the highway if everything else is tuned well but not around town.
Work on tuning the 360 and lose the holley.You will spend a lot of money on the swap with minimal gain.
Re: VooDoo cam in a 318 truck? [Re: gch] #998805
05/24/11 07:27 AM
05/24/11 07:27 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I've got a similar duration roller cam in a magnum headed 318 in my 4000 lb 5th ave. I average 17.5mpg mixed with it.
an '87 318 in a truck will be flat tappet, but should be a roller cam block. I'd look at the smaller voodoo roller, too...contact board member scratchinfortraction for details. he might have a used voodoo roller cam for sale, too.
2017 Grand Cherokee Overland
Re: VooDoo cam in a 318 truck? [Re: patrick] #998806
05/24/11 09:41 AM
05/24/11 09:41 AM
scratchnfotraction Offline
yep,mine is a high milage 360 headed 318 cop engine,never had the heads off,pushing I guess upwards of 275,000 miles
with patrick recomending the lunati 60710 roller cam for my 85 stepside truck
258/264
207/213
.485/.485
used a set of comp 901-16 springs,they drop on,are single with damper,use stock seals/retainers..no rotators-used 16 intake retainers
used all stock roller lifter/PR/hardware
lunati springs are a double and need machine work and guide/seal work
heres the rest of it,knocks back 18 mpgs and is now starting to get a little blow by,but runs strong and daily
LD4B intake
600 edelbrock carb
headers
2.5" duels
904 hs-lu tranz
8 3/4 3.23sg
has a point dist with pertronix conversion with flame thrower coil,by pass the ecu and BR runs full 12 volts to coil with conversion
not a race truck by a long shot but it does haull azz down the road
also have run the lunati 292/292 bracket cam with the comp 901-16 springs in a 360
choppy chop chop like a chebby but ran strong
used another voodoo also in a 360, the 230/230 @.050 range,I just built it for some one,ran good but never got any more feed back on it
Re: VooDoo cam in a 318 truck? [Re: scratchnfotraction] #998807
05/24/11 10:04 AM
05/24/11 10:04 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you do decide to convert to a roller, PM me, I have some good used roller lifters and pushrods out of my 5th ave (76k miles on them). I had to convert to magnum lifters that pushrod oil for my magnum heads.
you'd have to source the dogbone & spider lifter retainers, though...I sold my spares a few years ago.
