Re: Carpet with Roll Cage?
[Re: 408strokerdart]
#998403
05/23/11 03:22 PM
05/23/11 03:22 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Like to use carpet that has no backing. The edges do not ravel on this type of carpet. Just cut with a razor blade. A bolt hole for belts can be made with a large punch. Just heat the punch with torch and poke it through.
Leon
[Re: Leon441]
#998404
05/23/11 03:31 PM
05/23/11 03:31 PM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
Instead of a torch and punch to put holes in carpet, you can use a soldering iron if that's more handy.
Everybody makes fun of a hillbilly until they need something fixed
[Re: Leon441]
#998405
05/23/11 04:19 PM
05/23/11 04:19 PM
Posts: 3,456 Out West
408strokerdart
Out West
Leon
So...no edging required to make a finished looking edge? I don't have a problem with this since it makes it easier. I already pull the backing off because of the additional weight.
#998406
05/23/11 06:24 PM
05/23/11 06:24 PM
Posts: 4,696 On the parachute mount
n20mstr
the soldering gun trick works very well. and kind of "melts" the edge. Actually looks pretty finished when your done. Just go little at a time
....BAD A$$ STREET CAR.....
[Re: roadhazard]
#998408
05/23/11 09:19 PM
05/23/11 09:19 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Anyone just cut an "X" for bolts/fasteners and just fold the flaps closed when tight? Or does that look terrible?
383, Hemi 4-Speed, AlterKtion, D60
