Advice on Valve Cover gaskets- '67 440 #996039
05/20/11 09:08 AM
05/20/11 09:08 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
I used the red/orange valve cover gaskets that came with Mopar set..Haven't even installed Engine
into Car yet,took the valve cover off left bank
to make sure # one piston was at correct TDC for
setting Dist.and it looks like valve cover gasket
is gonna leak already,and I haven't even run Engine yet!! Somebody who's been thru this already
school Me on better gaskets to use??
Re: Advice on Valve Cover gaskets- '67 440 [Re: gassy66] #996040
05/20/11 09:45 AM
05/20/11 09:45 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
A good quality cork gasket, glued to the valve cover, a little bearing-grease smeared on the other side, has worked for me for decades. Gotta make sure the valve covers are straight/flat at their sealing surfaces. No leaks, not even a film.
Re: Advice on Valve Cover gaskets- '67 440 [Re: gassy66] #996041
05/20/11 09:45 AM
05/20/11 09:45 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Any VC gaskets should work fine. Just make sure the VC "rail" that the gasket sits-into is flat and not warped. And do NOT over-torque it.
I make it a practice to use a cast alum VC if possible.
Re: Advice on Valve Cover gaskets- '67 440 [Re: gassy66] #996042
05/20/11 10:46 AM
05/20/11 10:46 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I use MrGasket Ultraseal gaskets glued to cast aluminum covers with weatherstrip adhesive(gorilla snot). They have been on and off many times and never leak a drop.
