Tunnel ram intake #996028
05/20/11 08:08 AM
05/20/11 08:08 AM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
Does anyone run a tunnel ram intake in a B-body, I'm wondering how did you run the throttle cable and kick down cable I'm using the Lokar cable for the kick down mine has two 450 Holleys and a straight rod that connects the two I'll try to post some pics maybe someone has an idea of how to hook it up
Re: Tunnel ram intake [Re: KY Charger] #996029
05/20/11 08:53 AM
05/20/11 08:53 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
mines in an abody, but I've used the lokar setup on the throttle and kickdown.
I also used a rod to attach both carbs.
Re: Tunnel ram intake [Re: DJVCuda] #996030
05/20/11 09:48 AM
05/20/11 09:48 AM
Bowling Green, KY
K
K
Bowling Green, KY
Sweet looking ride and motor you've got mine is also a 360 but with the Weiand intake here is a pic of the current set up
Re: Tunnel ram intake [Re: KY Charger] #996031
05/20/11 10:53 AM
05/20/11 10:53 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
just an FYI - watch that type of rod connection between the 2 carbs - alot of times they are too small to fit the ID of the carb hole and one carb opens before the other causing issues at idle and tip in
