Turbo hot side done #995531
05/19/11 12:21 PM
05/19/11 12:21 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
My hot side is done. Two inch to three inch. 60mm hks waistgate. Bla bla bla
getting coated in 2000* black. Should look ok.
Re: Turbo hot side done [Re: FastmOp] #995532
05/19/11 09:28 PM
05/19/11 09:28 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Might wanna make up some heat shields for those rack dust boots
Re: Turbo hot side done [Re: CokeBottleKid] #995533
05/22/11 01:46 PM
05/22/11 01:46 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I can get my fingers between them
I start wires and fuel lines soon. Breaks are done and the list gets smaller every day. Still need a converter and change the cam in the motor but it's got a chance to see the dragstrip this fall
Re: Turbo hot side done [Re: FastmOp] #995534
05/22/11 02:22 PM
05/22/11 02:22 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Not enough room unless you are gonna wrap the pipes. That pipe will glow bright orange under a load and melt anything around it.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Turbo hot side done [Re: CUUDAK] #995535
05/22/11 02:46 PM
05/22/11 02:46 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I hope I can get it that hot.
Here's the car I'm building.
