I'm trying to work out the bugs on my T/A, so I can drive it to the Nats. (13 hours) Last nite on yet another trial run, my headlights started flashing when on high beams (and only after a few minutes on) when I kicked the switch down to low beams- it stopped. Waited a bit, went back to high beams, and they were fine again for a while, then started flashing again. I am assuming that either the foot switch is bad and getting hot, or the switch on the dash is taking a crap. I'll be needing my headlights for the trip- so I need to figure this one out. Any ideas? Thanks guys! Kirby
